Re: Who can CNC W2 heads?
[Re: Htownmopar]
#2256267
02/19/17 10:27 PM
02/19/17 10:27 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
Try modern cylinder head. They don't have W2 listed as a CNC option but may well do it. They don't have the eddies listed either, or W5, but know they do both of those
[Re: B3422W5]
#2256270
02/19/17 10:30 PM
02/19/17 10:30 PM
Posts: 6,150 Melbourne , Australia
LA360
Brett Miller, send him a PM. I think he has dabbled in these.
Larry Meaux would be the other person I would speak with, does a lot of Super Stock stuff
Alan Jones
[Re: Htownmopar]
#2256454
02/20/17 03:40 AM
02/20/17 03:40 AM
Posts: 3,505 DFW
mr_340
DFW
I had MCH do a set for me many years ago when Jeff was still around.
Floyd Lippencott IV
[Re: dwayne welder]
#2257780
02/22/17 03:33 PM
02/22/17 03:33 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I don't like the .300 lift numbers at all on that flow sheet. 179 @.300 is pathetic on a ported head. Especially on a head upgraded to a 2.08 intake valve.
[Re: pittsburghracer]
#2257787
02/22/17 03:49 PM
02/22/17 03:49 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I don't like the .300 lift numbers at all on that flow sheet. 179 @.300 is pathetic on a ported head. Especially on a head upgraded to a 2.08 intake valve. I don't think it matters much what the head does at 300 on a race head. The early numbers go right out the exhaust port
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2257796
02/22/17 04:20 PM
02/22/17 04:20 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I don't like the .300 lift numbers at all on that flow sheet. 179 @.300 is pathetic on a ported head. Especially on a head upgraded to a 2.08 intake valve. I don't think it matters much what the head does at 300 on a race head. The early numbers go right out the exhaust port Keep in mind everyone doesn't run an .800 lift cam in their small block or shift at 8000 plus RPM.
[Re: Htownmopar]
#2257806
02/22/17 04:45 PM
02/22/17 04:45 PM
Posts: 3,505 DFW
mr_340
DFW
That was Jeff's first go on the ports. He worked on them a bit more to pick up the lower lifts. My W5 heads did flow better than the .300" number and that was as cast with a Ø2.06" BBC stock valve.
Floyd Lippencott IV
#2257810
02/22/17 04:53 PM
02/22/17 04:53 PM
WHITEDART
bean town ....Ca
I don't like the .300 lift numbers at all on that flow sheet. 179 @.300 is pathetic on a ported head. Especially on a head upgraded to a 2.08 intake valve. I don't think it matters much what the head does at 300 on a race head. The early numbers go right out the exhaust port Keep in mind everyone doesn't run an .800 lift cam in their small block or shift at 8000 plus RPM. they dont? Well who cares then 😜.. John I'm just poking👉 carry on
#2257883
02/22/17 08:44 PM
02/22/17 08:44 PM
Posts: 494 IL
EchoSixMike
IL
I don't like the .300 lift numbers at all on that flow sheet. 179 @.300 is pathetic on a ported head. Especially on a head upgraded to a 2.08 intake valve. I don't think it matters much what the head does at 300 on a race head. The early numbers go right out the exhaust port Keep in mind everyone doesn't run an .800 lift cam in their small block or shift at 8000 plus RPM. Slackers. ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif) S/F....Ken M
[Re: killermopar]
#2257915
02/22/17 10:01 PM
02/22/17 10:01 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Heck that's where that W8 and W9 stuff starts coming on. Lol
#2257931
02/22/17 10:24 PM
02/22/17 10:24 PM
WHITEDART
bean town ....Ca
Heck that's where that W8 and W9 stuff starts coming on. Lol you bet RPM is king..8000 is good 9000 is better💣
