Muffler Question #2254945
02/17/17 10:57 AM
02/17/17 10:57 AM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
I have tried to search the site...but we all know how that goes. So, I thought I would just ask. I am wondering what the longest Dynomax Ultra Flo Welded muffler I can fit in a Cuda is? I think they make a 14", 20" and 24" case length. I will be doing 3" pipe and attempting to mount them in the stock muffler location.
Thanks in advance!
Re: Muffler Question [Re: Benforsp] #2255088
02/17/17 04:33 PM
02/17/17 04:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
Get under that rascal and do some measuring wrench grin
Re: Muffler Question [Re: Benforsp] #2255270
02/18/17 12:23 AM
02/18/17 12:23 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Not sure on an E-body, but I fit 24" cases under an early B; that car used 3" in and 2.5" out (tailpipes); tight fit on the tailpipes on that car around springs & frame rails & gas tank, which shouldn't be much of an issue on an E-body, I think.
When you're under there with the measuring tape, if you're planning on 3" tail pipes, remember that the 3" bend is gonna take up some room.
Re: Muffler Question [Re: topside] #2255391
02/18/17 07:30 AM
02/18/17 07:30 AM
Ohio
rck850 Offline
rck850  Offline
Ohio
On my Duster the 14" tucked up where it was supposed to. The 20 and 25 were too big to fit in the kick up area under the car. I want to say there is somewhere around 16-18" of room under there.
Re: Muffler Question [Re: rck850] #2255543
02/18/17 04:43 PM
02/18/17 04:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"stock muffler location" on an E-body is behind the axle.
Re: Muffler Question [Re: Benforsp] #2257105
02/21/17 12:21 PM
02/21/17 12:21 PM
an8sec70cuda Offline
Not sure exactly how long they are, but I used to have a pair of 4.5" diameter inlet/outlet, center/center, Flowmaster 2 chamber top 10 series race mufflers mounted in front the axle on my '70 cuda. Those mufflers are real thick, but not much longer than a typical performance muffler.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Muffler Question [Re: Benforsp] #2257124
02/21/17 01:00 PM
02/21/17 01:00 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
Thanks for the replies
Cab...I'm on the road most of the time so I don't always have access to the car. I try and get parts ordered before for when I get back.
John...I thought there were mufflers in front of the axle and resonators next to the tank?
An8sec70cuda...beautiful car. My exhaust will be the same as yours but with the 3" pipe and turn downs in the same position. My car is a street car so I am trying to keep it quieter with the Ultra-flo's. While I have your attention...I would love to hear how you have the rearend setup. I am building a 9" for mine but would live to have a similar tire size etc.
Re: Muffler Question [Re: Benforsp] #2257160
02/21/17 02:08 PM
02/21/17 02:08 PM
Thankyou! If I were you, I'd set your 9" rear up w/ the '68-'70 B body dimensions and use the Dr. Diff offset spring hanger kit to use a 15x10 rim. His kit allows you to bolt in a B body rear and fit a 10" wheel pretty easy.
Mine is a stock width E body rear w/ stock front spring location, but I use the .850" offset rear shackles to get some added clearance and to make the springs closer to parallel. They're wider at the rear in the stock configuration.
I use 15x8.5" wheels w/ 5" of backspacing and run both 295-65 radials or 29.5x10.5 slicks on it.
Just trimmed the inside of the wheelwell lip to clear the tires.
Here's a pic w/ the slicks on it.
CHIP
Re: Muffler Question [Re: Benforsp] #2257294
02/21/17 06:25 PM
02/21/17 06:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Other way around, the resonators (when installed) are in front.
Re: Muffler Question [Re: Benforsp] #2258597
02/24/17 10:37 AM
02/24/17 10:37 AM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
Thanks for the info John.
An8sec70cuda...thanks for that information. I think I am going to have to do some measuring etc. The 9" is about an inch shorter then stock. I may have to fab up some offset spring hangars and hope for the best or use Dr. Diffs. I am still collecting pieces. Love the hood also on the car. I just put one on 4' though.
