motor gurus, I need help #2255687
02/18/17 10:46 PM
02/18/17 10:46 PM
Friendly, WV
wedgeheaded Offline OP
Friendly, WV
Beautiful warm day here today and I decided to drive my old car. It has a 360 with a whiplash cam. I started it up and it was making a loud tapping/banging noise from the left side valve cover area. I pulled the VC and everything looked OK but I'm thinking I might have a stuck lifter. It's sat all winter but I've never had this happen before. Anybody have insights? Thanks in advance.
Re: motor gurus, I need help [Re: wedgeheaded] #2255698
02/18/17 11:10 PM
02/18/17 11:10 PM
agreed, a lifters innards may have become stuck. You might press straight down on each rocker (lifter side) with a wooden hammer handle & the problem child will change tone when you are on it. (eng idling). EDIT If you pin it down to (1) then you could pull it with the long claw tool & clean it.
Re: motor gurus, I need help [Re: RapidRobert] #2255897
02/19/17 10:01 AM
02/19/17 10:01 AM
Friendly, WV
Friendly, WV
OK. Do you think I could get the lifter out with a magnet? I have one of those that stretches out to make the reach easier. I'm thinking it's worth a try.
Re: motor gurus, I need help [Re: wedgeheaded] #2255901
02/19/17 10:35 AM
02/19/17 10:35 AM
Medford OR
FrankenScamp Offline
Medford OR
Yes. I just recently pulled one of mine w/a magnet
Re: motor gurus, I need help [Re: FrankenScamp] #2255913
02/19/17 11:40 AM
02/19/17 11:40 AM
Friendly, WV
Friendly, WV
Sounds like I have a plan of attack. Thanks guys!
Re: motor gurus, I need help [Re: wedgeheaded] #2255976
02/19/17 02:09 PM
02/19/17 02:09 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Let us know what you found....
Nautilus Racing-
Re: motor gurus, I need help [Re: wedgeheaded] #2256042
02/19/17 03:52 PM
02/19/17 03:52 PM
Did you let it warm up before stopping the motor? If not go drive it for a while, 20 + minutes to see if it will unstick and pump up scope twocents
Re: motor gurus, I need help [Re: Cab_Burge] #2256060
02/19/17 04:31 PM
02/19/17 04:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Re: motor gurus, I need help [Re: Cab_Burge] #2256173
02/19/17 07:04 PM
02/19/17 07:04 PM
Friendly, WV
Friendly, WV
No I didn't. While I'm pretty sure it's a lifter, what if it isn't? I've never heard one this loud. It's not a tick or tap, it sounds like a rod bearing is out, only on top. Kinda creeped me out. It ran fine when I parked it for winter so I can't think of anything else but I want to tear it down first. Going out now.
Re: motor gurus, I need help [Re: wedgeheaded] #2256190
02/19/17 07:59 PM
02/19/17 07:59 PM
Friendly, WV
Friendly, WV
OK, since I wa fairly sure it is a lifter I started it up again. I got it warmed up and noticed a miss but the clank never went away. I pulled the VC and checked the push rods for slop, nothing that screamed here's the problem. I spun each rod and the 5th rod from the front would not spin. I pulled the rockers out and pushed down on the 5th rod, spongy. All the rest are tight, like they're sitting on iron. I pushed the rod down several times and felt the spring pushing back. I'm going to put everything back and see what I get.
Re: motor gurus, I need help [Re: wedgeheaded] #2256195
02/19/17 08:08 PM
02/19/17 08:08 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sometimes an exhaust leak can sound mechanical.
What ever you find, let us know and good luck to you.
I have mechanical Aptitude.
I can screw up anything.
Re: motor gurus, I need help [Re: wedgeheaded] #2256213
02/19/17 08:42 PM
02/19/17 08:42 PM
Friendly, WV
Friendly, WV
I just put everything back together and it's no better. For what ever reason the 5th lifter isn't pumping up. My biggest hope is that I've not damaged the cam. I'm going to have to pull the intake next friday afternoon. (my first 8hr day) What sucks the most is, it's an AC car, lots of extra stuff to pull off. I hope it's just a bad lifter and not a wiped out lobe. I'm more of a body/paint guy than a mechanic so I'm out of my element. Wish me luck.
Re: motor gurus, I need help [Re: wedgeheaded] #2256218
02/19/17 08:52 PM
02/19/17 08:52 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
If the face of that lifter looked good then the cam should be fine.
Replace that lifter. I had the same problem on a 318 years ago and a new lifter fixed it.
Re: motor gurus, I need help [Re: wedgeheaded] #2256277
02/19/17 10:35 PM
02/19/17 10:35 PM
Friendly, WV
Friendly, WV
I have high hopes that it's just the lifter. The fact that the others will not compress when I press on the push rods, but this one feels springy, is my hope. The fact that it's making so much noise and is consistent says that something is moving a lot and moving consistent, hopefully because a cam lobe is moving stuff. I'll know when I know.
Can I pick up a new lifter from advance or will I need to go back to Hughes wheer I bought the cam, springs, and lifters?
Re: motor gurus, I need help [Re: wedgeheaded] #2256316
02/19/17 11:38 PM
02/19/17 11:38 PM
wouldn't hurt to talk to Dave & pick his brain, he's an easy guy to talk to. Offhand I'd say any lifter would work fine & you do need to go thru the cam breakin procedure again just like if it was a completely new cam/lifter breakin. EDIT I would open up the bad lifter & see if anything you see is wrong especially since you will be swapping it without removing the intake & an easy solution would be nice. what would be real good is if you had an identical new or used lifter (some are different inside) & could compare its innards to the bad one & depending on what I found I might even swap some of those pieces cuz a cam breakin is a bit of a pain & it is the outer lifter bottom to lobe contact that is critical but you might just want to be done with it. Actually I think it has a bit of dirt in there & cleaning will fix it. Holler how it turns out.
Re: motor gurus, I need help [Re: wedgeheaded] #2258296
02/23/17 07:41 PM
02/23/17 07:41 PM
Friendly, WV
Friendly, WV
I bought 2 new lifters from Hughes Engines.(1 spare) I bought new break in oil and a pair of filters. I plan to swap it out sat, break it in, do an oil change back to reg oil and swap out a leaking PS pump and hose. I will tear down the lifter just to see if I can determine why it failed.
Re: motor gurus, I need help [Re: wedgeheaded] #2258359
02/23/17 10:11 PM
02/23/17 10:11 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Just for chitz & giggles check the converter bolts.I had one loosen up,,,,,,,,,,,,,I thought it was a rod bearing.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: motor gurus, I need help [Re: wedgeheaded] #2258459
02/24/17 01:06 AM
02/24/17 01:06 AM
Go drive the car for more than enough time to get the oil temps up above 150 F to see that hot oil will fix that lifter.
Motors absorb water by condensation into their inside when sitting in cold weather, no matter where you live shock I saw that happen in the Mojave desert in late March and April when it was no lower than 60F outside air temps at night puke
Water and other things will stick in the little valve inside the lifter causing what your experiencing, trust me on that thumbs
Run it down the road at a steady cruising speed of above 2100 RPM for enough time to get the oil hot and that should help it get better scope
I quit buying The Mopar brand Purple Shaft cam kits due to their low quality lifters sticking and ticking like your is doing now shruggy
We lived in the Mojave desert where it would be 105 F in the day and drop down to the upper 60s F at night, we lived in one of the better spots in SO CA in the Mojave desert, north 30 miles it got up to 117 F during the days and 85 F at night, the further east, north and south you went in that desert the hotter it got shruggy
Good luck thumbs
Re: motor gurus, I need help [Re: wedgeheaded] #2258511
02/24/17 02:29 AM
02/24/17 02:29 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Lifters rarely(as in very rarely) go bad(fail) from sitting.
I would have run it for quite a while before changing any parts.
If the lifter simply refused to pump up, it's almost certain there is a tiny piece of debris in the lifter.
Take it out, take it apart, spread all the pieces out on a clean white paper towel....you'll probably be able to find the reason it won't pump up.
Remove debris, reassemble, submerge in a cup of oil, pump plunger up and down a few times.......it should pump right up.
Obviously, while it's out...... Inspect the face for abnormal wear.
Re: motor gurus, I need help [Re: wedgeheaded] #2258564
02/24/17 05:08 AM
02/24/17 05:08 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I had a brand X that had a "stuck" lifter clattering. Even after it was warmed up it was still banging away. I put it on fast idle and started pouring a quart of ATF in it and it magically pumped up before the quart was empty and never clattered again as long as I had it.
Beats taking it apart if it works. shruggy luck
Kevin
