Piston Thermal Coating #2254345
02/16/17 12:12 AM
02/16/17 12:12 AM
San Diego, CA
mopar_man619 Offline OP
San Diego, CA
considering coating the pistons for my build. gen 3 hemi under bewst. intercooled. 9:1 comp. what do you guys think about thermal coating. this gen 3 and bewst will be new to me so there will be a learning curve thinking about it for insurance but would it be a waste ? its a reverse dome forged piston with side skirts already coated.
1967 Plymouth Valiant Gen III Hemi
11.42@119
youtube.com/moparman619
Re: Piston Thermal Coating [Re: mopar_man619] #2254349
02/16/17 12:18 AM
02/16/17 12:18 AM
San Diego, CA
San Diego, CA
11.42@119
Re: Piston Thermal Coating [Re: mopar_man619] #2254350
02/16/17 12:20 AM
02/16/17 12:20 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I do, cost in the big picture is not major, don't see how it could hurt, the big "but" for me, how long/well does it last? bump
Re: Piston Thermal Coating [Re: mopar_man619] #2254466
02/16/17 10:28 AM
02/16/17 10:28 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I hard anodized mine.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Piston Thermal Coating [Re: mopar_man619] #2254529
02/16/17 01:07 PM
02/16/17 01:07 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
A buddy of mine is building a turbo LS for his teen age son to drag race and he Cerakoted the tops of the pistons, chambers and valves. It hasn't ran yet so I don't know how it'll hold up.
Re: Piston Thermal Coating [Re: mopar_man619] #2254565
02/16/17 01:47 PM
02/16/17 01:47 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I would do something for a coating on that piston. Scary close relief for boost.
Re: Piston Thermal Coating [Re: mopar_man619] #2254601
02/16/17 02:58 PM
02/16/17 02:58 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Sharp edges are NOT your friend...
Re: Piston Thermal Coating [Re: Dave Hall] #2254915
02/17/17 07:17 AM
02/17/17 07:17 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
yeah i was looking at that and thinking detonation city...
there are some awfully thin bits on the top of that piston, is it a shelf or custom?
Re: Piston Thermal Coating [Re: mopar_man619] #2254979
02/17/17 12:47 PM
02/17/17 12:47 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I will be coating the dome & skirts this time around,,,,,,,,,,
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Piston Thermal Coating [Re: hemi-itis] #2255089
02/17/17 04:34 PM
02/17/17 04:34 PM
Maybe that top ring land needs to be a little further down away from the valve relief work
Re: Piston Thermal Coating [Re: mopar_man619] #2255098
02/17/17 05:01 PM
02/17/17 05:01 PM
an8sec70cuda Offline
My 572 hemi pistons were spec'd for a heavy dose of nitrous and got the domes ceramic coated by Diamond. It's the tan or gold colored coating. Can't say much for it as they've been that way since new. Haven't hurt one yet.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Piston Thermal Coating [Re: Cab_Burge] #2255412
02/18/17 11:06 AM
02/18/17 11:06 AM
hemi-itis Offline
hemi-itis  Offline
Originally Posted By Cab_Burge
Maybe that top ring land needs to be a little further down away from the valve relief :worng drik:
Maybe a little work Seems the top Moly ring failed,,,,,,
Re: Piston Thermal Coating [Re: mopar_man619] #2255635
02/18/17 08:47 PM
02/18/17 08:47 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
I thought moly rings and boost don't mix cause boost knocks the moly coating off them.....
Re: Piston Thermal Coating [Re: Blown 68 R/T] #2255853
02/19/17 02:41 AM
02/19/17 02:41 AM
hemi-itis Offline
hemi-itis  Offline
You think I was surprised when the Moly was knocked off and the ring failed blush
Nitrated titanium next round,,,,,,,,
Re: Piston Thermal Coating [Re: hemi-itis] #2255881
02/19/17 04:36 AM
02/19/17 04:36 AM
Are you sure you don't want some tool steel top rings for boost work
Re: Piston Thermal Coating [Re: Cab_Burge] #2258078
02/23/17 03:39 AM
02/23/17 03:39 AM
hemi-itis Offline
hemi-itis  Offline
Down to 2 choices,,,Nitraded titanium or Hellfires confused
