Re: riddle me this ... engine test stand ?? [Re: Stanton] #2254353
02/16/17 12:25 AM
02/16/17 12:25 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
So would a torque convertor work with a manual bellhousing
I'm going to go out on a limb and say that it probably would in an 11" clutch bell. My reasoning is that the 11" bell is the largest and both bell and auto trans have to fit the same tunnel in the body. Now whether or not the converter needs to be supported at the rear I can't answer.
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2254358
02/16/17 12:34 AM
02/16/17 12:34 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
I wouldn't attempt to use a torque converter unless you also use a functional transmission attached. You can use the converter front cover and ring gear with the guts removed with a bellhousing , auto trans case,or a fabricated starter mount if you like .
Re: riddle me this ... engine test stand ?? [Re: J. Hammer] #2254401
02/16/17 01:40 AM
02/16/17 01:40 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Correct, if you use a convertor that has the guts in it, the internals will wobble around and cause an out of balance condition. I've used a 130 tooth flywheel with my 727 bell and it works just fine so I don't see why a convertor wouldn't work with a manual bell. This 340 is running in this pic, 130 tooth flywheel with a cut off 727 bell. A 143 tooth flywheel won't fit in a 727 bell.
Re: riddle me this ... engine test stand ?? [Re: GODSCOUNTRY340] #2254447
02/16/17 05:51 AM
02/16/17 05:51 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Originally Posted By GODSCOUNTRY340
I built mine with trailer hubs and a tongue so it can be moved from place to place.
Pretty cool idea. up
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2255313
02/18/17 01:31 AM
02/18/17 01:31 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I made mine after a trip to the metal recycler...
I use a bellhousing and fluwheel, and the rear mount can be swapped with a wood block to run an automatic complete including running through the gears.
Re: riddle me this ... engine test stand ?? [Re: Stanton] #2255562
02/18/17 05:52 PM
02/18/17 05:52 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I made a bracket that bolts to the block using a bellhousing locating pin for reference; tested it on one of my motors on a run-stand and it worked fine. I used to sell them and valve-cover spacers when I had my tool biz. Wasn't enough of a market for that stuff for me to break even.
All it takes is a small flat bracket; mine were jet-cut 3/8" aluminum.
