Stock 14" rims for disc brakes will clear the stock Mirada brakes.
Have you tried test fitting the aftermarket 14" rims yet? They may clear as well.
one thing to watch on 14" aftermarket wheels is the balance weight to caliper clearance. the wheel may clear the caliper ok when test fit without weights installed, but when the tire is mounted and balanced, those weights "might" not clear and be knocked off driving from the shop. this can happen with stick on or [if the wheel is designed for them] normal clip on weights.
![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
