Re: riddle me this ... engine test stand ??
[Re: Stanton]
#2254353
02/16/17 12:25 AM
02/16/17 12:25 AM
Posts: 9,038 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
So would a torque convertor work with a manual bellhousing I'm going to go out on a limb and say that it probably would in an 11" clutch bell. My reasoning is that the 11" bell is the largest and both bell and auto trans have to fit the same tunnel in the body. Now whether or not the converter needs to be supported at the rear I can't answer.
[Re: J. Hammer]
#2254401
02/16/17 01:40 AM
02/16/17 01:40 AM
Posts: 2,564 God's Country Maryland
GODSCOUNTRY340
I wouldn't attempt to use a torque converter unless you also use a functional transmission attached. You can use the converter front cover and ring gear with the guts removed with a bellhousing , auto trans case,or a fabricated starter mount if you like . Correct, if you use a convertor that has the guts in it, the internals will wobble around and cause an out of balance condition. I've used a 130 tooth flywheel with my 727 bell and it works just fine so I don't see why a convertor wouldn't work with a manual bell. This 340 is running in this pic, 130 tooth flywheel with a cut off 727 bell. A 143 tooth flywheel won't fit in a 727 bell.
[Re: GODSCOUNTRY340]
#2254447
02/16/17 05:51 AM
02/16/17 05:51 AM
Posts: 10,308 A Red State
SNK-EYZ
A Red State
I built mine with trailer hubs and a tongue so it can be moved from place to place. Pretty cool idea.
[Re: Stanton]
#2255313
02/18/17 01:31 AM
02/18/17 01:31 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I made mine after a trip to the metal recycler... I use a bellhousing and fluwheel, and the rear mount can be swapped with a wood block to run an automatic complete including running through the gears.
