Re: 36-1 crank trigger for EFI
[Re: AndyF]
#2251492
02/11/17 09:56 AM
02/11/17 09:56 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Nice. I really like the pulley center and attention to balance. It's difficult to see from the picture angle, but it looks like it should be a little larger. Many sensors require 1/2" of distance from rotating ferrous materials.
[Re: Stanton]
#2251548
02/11/17 12:05 PM
02/11/17 12:05 PM
Posts: 24,069 Here
jcc
No soup for you!!!
No soup for you!!!
Here
Very nice , two things, since its obviously steel and CNC, how tough would it be to add a ring of lightening holes, if for nothing else, eye candy, and what thickness are the teeth?
I forbid my content here from being learned and used by artificial intelligence systems.
[Re: AndyF]
#2251608
02/11/17 01:22 PM
02/11/17 01:22 PM
Posts: 9,208 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
It's great to see some higher quality EFI components for the Mopar contingency I'd like to hear the justification for a billet wheel versus a laser cut or waterjet cut unit out of 1/8 plate at a fraction of the cost. Eye candy - yuh, that's about it !! Don't get me wrong, I'm not knocking Andy's product. But like the billet valve covers, I don't see the point.
[Re: Stanton]
#2251623
02/11/17 01:37 PM
02/11/17 01:37 PM
TRENDZ
Milwaukee WI
It's great to see some higher quality EFI components for the Mopar contingency I'd like to hear the justification for a billet wheel versus a laser cut or waterjet cut unit out of 1/8 plate at a fraction of the cost. Eye candy - yuh, that's about it !! Don't get me wrong, I'm not knocking Andy's product. But like the billet valve covers, I don't see the point. There will always be cost to benefit debates. I make my own trigger wheels(very economical), but if you put mine next to Andy's and asked me which one I want, I'd grab Andy's and run!
[Re: Mopar_Rich]
#2251626
02/11/17 01:46 PM
02/11/17 01:46 PM
Posts: 31,333 Oregon
AndyF
It's great to see some higher quality EFI components for the Mopar contingency. Have you considered special V pulleys to compensate for the thickness? Doty makes a pulley that is the correct height to work with an ATI damper and this trigger wheel. I don't have a picture of it but I mocked it up and the alignment is pretty close.
[Re: TRENDZ]
#2251629
02/11/17 01:55 PM
02/11/17 01:55 PM
AndyF
Nice. I really like the pulley center and attention to balance. It's difficult to see from the picture angle, but it looks like it should be a little larger. Many sensors require 1/2" of distance from rotating ferrous materials. It is possible that it needs to be larger, we'll see. I'm running an aluminum shell on the ATI damper so I think this will work just fine. The damper is 7 inches diameter and the wheel is 7 3/4 so there should be enough of a gap for the trigger to work. Working with billet steel allows me to machine the center and add the other 3D features. I put a dot at the TDC tooth and scribed a line for the sensor tooth. I designed it per the Holley instructions so at TDC the sensor is on the 7th tooth after the gap.
[Re: Stanton]
#2251806
02/11/17 07:09 PM
02/11/17 07:09 PM
Posts: 6,190 Melbourne , Australia
LA360
It's great to see some higher quality EFI components for the Mopar contingency I'd like to hear the justification for a billet wheel versus a laser cut or waterjet cut unit out of 1/8 plate at a fraction of the cost. Eye candy - yuh, that's about it !! Don't get me wrong, I'm not knocking Andy's product. But like the billet valve covers, I don't see the point. Weight, if done right, you can get a billet cover lighter than any fabricated cover.
Alan Jones
[Re: Stanton]
#2251814
02/11/17 07:26 PM
02/11/17 07:26 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
It's great to see some higher quality EFI components for the Mopar contingency I'd like to hear the justification for a billet wheel versus a laser cut or waterjet cut unit out of 1/8 plate at a fraction of the cost. Eye candy - yuh, that's about it !! Don't get me wrong, I'm not knocking Andy's product. But like the billet valve covers, I don't see the point. Not exactly correct. The main reason the 36-2 wheel is not real popular is because they are thin and flex in higher HP applications. We had to do some machining and weld 3 of the thin ones together to get ours to work consistently. We finally just opted to put a flying magnet on ours with the hall effect sensor and be done with it. Which is fine if you run a cam sensor. The advantage of the 36-2 is that it can detect number one cylinder approaching. That is what the gap is for. This allows you to run sequential without a cam sensor
[Re: AndyF]
#2251931
02/11/17 10:52 PM
02/11/17 10:52 PM
Posts: 24,069 Here
jcc
No soup for you!!!
No soup for you!!!
Here
That's a healthy tooth thickness at .370", since the signal is just a s/N ratio issue, with alum damper shell, a larger dia reluctor, and fact others use .125" and .187" thickness rotors, this should be pretty solid signal platform. I am puzzled how Monte senses #1 TDC without a cam sensor, or is it a wasted spark set-up non sequential?
[Re: AndyF]
#2252087
02/12/17 05:07 AM
02/12/17 05:07 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
AndyF, I need this for small block Mopar, please tell me you are making it for small block also?
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: AndyF]
#2252127
02/12/17 09:34 AM
02/12/17 09:34 AM
TRENDZ
Milwaukee WI
BB and small block should be the same. Maybe different diameter balancer options?
[Re: AndyF]
#2252180
02/12/17 11:24 AM
02/12/17 11:24 AM
Posts: 8,127 Tulsa OK
Bad340fish
Tulsa OK
That looks very nice! If you have one with the 6 bolt pattern on it I will probably get one of those. I have a Morosso crank pulley and it is no big deal to chuck it on a friends mill and shave some more off of the back of it.
I have a very thin laser cut wheel a friend of mine made for me. It works great but it is thinner than anything on the market. The only time I have had a sync loss problem was when I moved my stuff over to my current engine and did not recheck sensor gap.
68 Barracuda Formula S 340
