Re: Need info on E-Body "Rock" signed cars
[Re: Dixie]
#2252189
02/12/17 12:34 PM
02/12/17 12:34 PM
Posts: 29,679 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
He signed Dodges & Plymouths, A & E-bodies.
Was that a common practice to switch lines between makes and body styles? Yes, they were all mixed up & at times, cars with VINs over 30,000 apart were actually very close on the lines.
[Re: Alaskan_TA]
#2252202
02/12/17 12:47 PM
02/12/17 12:47 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
Was that a common practice to switch lines between makes and body styles? Yes, they were all mixed up & at times, cars with VINs over 30,000 apart were actually very close on the lines. Wow, thinking about the required logistical management to have the right parts at the right time for that particular car must have been tough! Not to mention training of the employees on assembling different cars.
[Re: Dixie]
#2252590
02/12/17 10:08 PM
02/12/17 10:08 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
It's not that hard. They had an order that the cars were going to go through. The sections would line up parts in that order. The line worker has very few tasks. Grab the part presented in order and install part. The variation from car to car is not that great. There was probably a verification step for more complicated assemblies like steering columns.
[Re: cudanut]
#2253156
02/13/17 09:05 PM
02/13/17 09:05 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Now a Word REPAIR but in rock hand proves my point its an inspection mark He was checking the rear operators. Please post a picture mystery would be solved. OK, but you said; I don't think this s a persons name . If not a name, what kind of inspection mark is 'Dickie' if it is not a name? If you missed it, I posted a link to photos of other names from cars on the assembly lines earlier in the thread.
[Re: Alaskan_TA]
#2253591
02/14/17 04:18 PM
02/14/17 04:18 PM
Posts: 71 Sudbury, ontario canada
750-h2
This practice still goes on today. Many new Challengers get signed [usually under the fuse box cover] BB with a happy face. BB has been identified as Brampton Builder which is quite active on the new Challenger forums.
[Re: Dixie]
#2253674
02/14/17 07:24 PM
02/14/17 07:24 PM
Posts: 5,127 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Yes, they were all mixed up & at times, cars with VINs over 30,000 apart were actually very close on the lines. [/quote]
Wow, thinking about the required logistical management to have the right parts at the right time for that particular car must have been tough! Not to mention training of the employees on assembling different cars. [/quote]
This is why the Sequence number is easy to see at the top left of a broad cast sheet that drives the production of Vehicles, not the Vehicle Identification Number, VIN. Not sure why ROCK was put on any vehicle, an inspector would have a punch either that would put his assigned number punched into a broad cast or work sheet or and ink stamp punch. You see some of these ink inspection stamps on cars that have been stamped with OK in the engine compartment usually on or near the radiator cradle. Also there are other production sheets all over the plant that never make it into any vehicle telling the workers about what to sub assemble, the sequence number is the order on which the worker uses to build, not the VIN.
[Re: hemicar1971]
#2253780
02/14/17 11:33 PM
02/14/17 11:33 PM
Posts: 196 NJ
JH23
NJ
Rock was the one who threw the chicken bones inside the doors before the panel was installed. ROCK Cornish Game Hen.
[Re: Dixie]
#2266225
03/09/17 03:23 PM
03/09/17 03:23 PM
Posts: 135 Parsippany, New Jersey
340challconvert
I have seen Rock on a number of ebodies. When I took out the back seat and panels on my 70 A66 Challenger, I found the name "AL". Anyone ever seen this one before?
1970 A-66 340 Challenger convertible
[Re: cudanut]
#2290224
04/18/17 08:35 PM
04/18/17 08:35 PM
Posts: 4,165 Florida
cataclysm80
My 1970 'Cuda with a late June SPD had "Repair" written on the interior passenger rear wheel well.
At first I thought it said "Rock" because the R was very similar, and it was sort of hard to read, but when I really got to looking at it, it definitely said "Repair".
Everything looked fine to me, so I'm not sure what needed repair. I suppose they already fixed whatever it was?
Not sure if I have pics. (at least not good ones)
Tav Please post a picture mystery would be solved. Sorry for the delay, I've been overly busy with other things, and am just getting back to working on cars again. I'm surprised that I had a pic which was even this good. The "Re" is difficult to see in this pic, but you can see the "pair" fairly well. I really miss the old days when Moparts had its own image uploader. It had size restrictions, but it worked pretty well. Photobucket is a big POS! What do you guys use for image hosting so that you can post pics here?
[Re: 6bblgt]
#2294340
04/26/17 07:18 AM
04/26/17 07:18 AM
cataclysm80
it's pretty easy once you get a tutorial Wow, That's probably EXACTLY what I needed!! That will make life so much easier!
[Re: B5Cuda440-6]
#2294342
04/26/17 07:21 AM
04/26/17 07:21 AM
cataclysm80
I have to use "Snagit" to cut-down the size of all the photos I upload. Most pictures I take with my phone exceed the file size allowed (2MB) for upload directly. Thanks, I think the old file size limit was 1.5 MB. I have photoshop now, so resizing pictures is WAY easier for me than it used to be.
