Re: engine paint question [Re: mopar rookie] #2250127
02/09/17 01:47 AM
02/09/17 01:47 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
These preval thingies. The spray pattern is a big circle and you can't tip the unit beyond 45 degrees? How do you paint a horizontal surface? How do you get even coverage out of a cone spray vs a fan?
**Photobucket sucks**
Re: engine paint question [Re: 70Cuda383] #2250146
02/09/17 02:16 AM
02/09/17 02:16 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I would not attempt to use one to paint something large and flat like a hood on some sawhorses for example. No way would you get a nice even finish on something that large with a Preval. You could use one to apply a two part primer on a hood if you wanted as you would eventually sand it and paint it later with a real paint gun.
I use them for priming parts (big and small), and painting smallish things. I have painted engine blocks and heads with them and they came out with a nice even finish. Rough cast iron engine parts are very forgiving with any paint.
Doing an oil pan and valve covers works if you have the paint mixture aligned with the air temp so it flows out smooth. Too much reducer and you'll get runs. Not enough and its orange peel city - same as with a real paint gun.
They do leak if you tilt them too far back when the jar is full. The propellant will ice up and stop spraying if you hold the trigger down continuously. For painting an engine that should not be an issue.
https://youtu.be/bO_LCNHA5Vc
Re: engine paint question [Re: Neil] #2250265
02/09/17 12:12 PM
02/09/17 12:12 PM
Neil that is good additional Preval info. I ain't never used one but I will keep all of your experience in mind if/when I do.
