Page 2 of 3 1 2 3
Re: Measuring for pushrod length. [Re: mopar dave] #2247997
02/05/17 08:31 PM
02/05/17 08:31 PM
Originally Posted By mopar dave
not sure, but I have the max wedge port. would that be the super victor? I hope so, because that's how the rockers were ordered. they are suppose to be a bit shorter than the standard victor.
The M.W. size ports are the Super Victors up
I look for 1/2 thread to three full threads max under the rocker arms on my Harland Sharps up
Re: Measuring for pushrod length. [Re: mopar dave] #2248000
02/05/17 08:37 PM
02/05/17 08:37 PM
Washington
madscientist Offline
Washington
Not running much spring pressure with the solid flat tappet. Didnt think it would hurt to use a heavy wall 5/16 pushrod and skip all the clearancing issues. Been there done that. Heres where the rockers set on the stem.
Yup a heavy wall 5/16 will work, but don't forget you can get 11/32 diameter as well. I wanted 3/8 but no way could I get it so I went 11/32 heavy wall and I think it is .125 wall.
Re: Measuring for pushrod length. [Re: madscientist] #2248016
02/05/17 08:54 PM
02/05/17 08:54 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
didn't know that 11/32 was available. glad to have another option. cab, will the adjusters still pass oil to the fulcrum at 3 threads? how many turns/threads shut the oil off. need to know the limit.
Re: Measuring for pushrod length. [Re: Jeremiah] #2248023
02/05/17 09:04 PM
02/05/17 09:04 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Jeremiah
While the OAL of the valves is equal the margin on the exhaust has a little more area between the margin and the face. You should see this when checking valve spring installed height as well. I'm 99% sure that is why you are seeing a variation from intake to exhaust.
It's the geometry effect of the offset intake rockers. Picture a triangle that starts at the lifter: the vertical line represents the pushrod length for the no-offset exhaust rocker; the horizontal line at the top of the triangle represents the intake rocker offset; the angled line from the lifter to the other end of the horizontal line is the longer pushrod for the offset intake rocker.
Exhaust valve lengths for inline valve engines are usually longer than intakes because of the thicker valve margins. The effective seat-to-tip lengths are virtually the same.
Re: Measuring for pushrod length. [Re: BradH] #2248063
02/05/17 10:11 PM
02/05/17 10:11 PM
PORT ORANGE FL.
gtea1901 Offline
gtea1901  Offline
PORT ORANGE FL.
yes Steward Performance great quality and priced right
stewardperformance.com
Re: Measuring for pushrod length. [Re: mopar dave] #2248070
02/05/17 10:27 PM
02/05/17 10:27 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I use Trend Performance push rods for all my builds. Please support your made in Michigan guys😎
Re: Measuring for pushrod length. [Re: gtea1901] #2248647
02/06/17 06:40 PM
02/06/17 06:40 PM
Mt Morris Michigan
Mt Morris Michigan
called steward for pushrods. $10ea for 5/16 .120 wall. says they will work fine with flat tappet@.650" lift. no 11/32 available. Manton wants $16ea. from what I see on the price list.
Re: Measuring for pushrod length. [Re: mopar dave] #2248828
02/06/17 11:45 PM
02/06/17 11:45 PM
Call Manton (951-245-6565) direct and get the racer price, if they offer it to you up scope twocents
Re: Measuring for pushrod length. [Re: mopar dave] #2248837
02/06/17 11:56 PM
02/06/17 11:56 PM
Washington
Washington
Smith Brothers does 11/32.
I'm of the mind you can never get a stiff enough pushrod.
Re: Measuring for pushrod length. [Re: Cab_Burge] #2248839
02/06/17 11:58 PM
02/06/17 11:58 PM
Mt Morris Michigan
Mt Morris Michigan
I will give them a call before I order any thing. stewards about same price as smith bros. stewards ships same day you order.
Re: Measuring for pushrod length. [Re: mopar dave] #2248993
02/07/17 10:49 AM
02/07/17 10:49 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Once you determine the pushrod length.
Go on ebay and type that length in .025" increments. Your search should be nascar pushrod 9.125". You may be surprised how cheap you can find a double taper trick of the century pushrod made by companies like manton, trend and some of the same sold under another name such as cv products.
Its a long shot when they are this long. But, I have bought double taper high radius 9/16" pushrods for $30 for set of 8.
Re: Measuring for pushrod length. [Re: Leon441] #2249031
02/07/17 12:28 PM
02/07/17 12:28 PM
Mt Morris Michigan
Mt Morris Michigan
my lengths are 9.200/9.250. I have to be careful how far I stray away from those lengths as every turn of the adjusters is equal to .050 and I don't want to block my oil flow at the adjuster which happens at 3 threads or more out and -1 thread in. I measured lengths at 1 thread out. I will take a look thou.
Re: Measuring for pushrod length. [Re: mopar dave] #2249103
02/07/17 02:40 PM
02/07/17 02:40 PM
Mt Morris Michigan
Mt Morris Michigan
I just got off the phone with Manton. They recommend 3/8 pushrod, but said I could get away with 11/32 .120 wall with the 400# open pressures. $12.35ea. Think i'll get the Mantons.
Re: Measuring for pushrod length. [Re: mopar dave] #2249105
02/07/17 02:43 PM
02/07/17 02:43 PM
Washington
Washington
I agree. Most pushrod aren't stiff enough.
I went with the same deal as you are considering. I damn near bought 11/32-5/16 single taper pushrods but I'm getting ready to do W-2 heads so I said screw it.
That engine will get 3/8-7/16 double taper pushrods even tough it will be SFT.
Re: Measuring for pushrod length. [Re: madscientist] #2249106
02/07/17 02:46 PM
02/07/17 02:46 PM
Mt Morris Michigan
Mt Morris Michigan
Manton told me the 11/32 .120 pushrods are 40-50% stronger than a 5/16 .120
Re: Measuring for pushrod length. [Re: mopar dave] #2249110
02/07/17 02:49 PM
02/07/17 02:49 PM
Washington
Washington
I'd believe them.
Re: Measuring for pushrod length. [Re: madscientist] #2249134
02/07/17 03:36 PM
02/07/17 03:36 PM
Mt Morris Michigan
Mt Morris Michigan
pushrod are ordered and I did get the jobber price. thanks guys
Re: Measuring for pushrod length. [Re: mopar dave] #2250104
02/09/17 01:09 AM
02/09/17 01:09 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
So I take it you won't be ordering the Michigan made Trend pushrods? I could have gotten you a great deal.
Re: Measuring for pushrod length. [Re: ccdave] #2250150
02/09/17 02:27 AM
02/09/17 02:27 AM
Mt Morris Michigan
Mt Morris Michigan
Not this time around. I was told summit racing pushrods are made by trend. Is that true. Never had Mantons and wanted to give them a try.
Re: Measuring for pushrod length. [Re: mopar dave] #2250162
02/09/17 03:06 AM
02/09/17 03:06 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I like to support my Michigan based companies for aftermarket parts. It's nice to put a name with a face and be able to actually see the facility where your parts are coming from. I save on time and shipping as well. Lot's of great high performance parts companies right in your back yard.
Page 2 of 3 1 2 3
