Re: Bare metal look
[Re: buzz440]
#2247408
02/04/17 10:18 PM
02/04/17 10:18 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I actually use Plasti-cote cast aluminum engine paint and it looks very close to bare metal and holds up well even when used in high heat situations. Grab a can of all the stuff you think you might want to use and do spray outs to see what matches the closest in your view.
Careful, your character's showing!
Re: Bare metal look
[Re: buzz440]
#2248917
02/07/17 02:14 AM
02/07/17 02:14 AM
Posts: 1,651 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Jeff Lilly is a restorer who contributes to restoration magazines and has done research on this topic. He shares his results with good information here: http://www.jefflilly.com/ > Build Tips > silver paints He tested 18 different rattle can paints that are supposed to give a bare metal look for cast iron, cast aluminum, bare steel, etc. He says that the kind of light in which the part will be viewed should be the test criteria. A control arm would be viewed in well shaded natural light at a car show. If so, then his choice for bare steel is Seymour Stainless Steel 16-054, photo #18 on the web. Maybe what is implied is that this paint is too light in direct sunlight but a good match if in the shade. He also likes Plasti Kote 285 but calls it a cast iron paint.
Re: Bare metal look
[Re: buzz440]
#2251203
02/10/17 07:20 PM
02/10/17 07:20 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
But But But a lower control was not bare steel, they were dipped in cosmoline ...
