What water addititive for leaky Cometics ?
#224526
02/14/09 02:56 PM
02/14/09 02:56 PM
Posts: 428 Mountain City, TN
JesseR
Mountain City, TN
What are you guys using for leaky cometics? I have a small leak between the 3 and 5 cylinder. This is my first go around with cometics so i don't really know what to use. Thanks, Jesse
82' dodge pickup with a 499 low deck
Re: What water addititive for leaky Cometics ?
[Re: JesseR]
#224527
02/14/09 03:17 PM
02/14/09 03:17 PM
Posts: 3,998 GO BUCKS !!!!!!!
340RICK
GO BUCKS !!!!!!!
My W5's did the same thing once I got a few heat cycles in, it stopped leaking. Is this a new build I hope????????? I have had sucess with the Moroso ceramic engine sealer it will seal up anything
[Re: 340RICK]
#224529
02/14/09 03:26 PM
02/14/09 03:26 PM
JesseR
Mountain City, TN
Yes, it is a new build with W5's also. I've only heat cycled it a few times, but it didn't start leaking unitl the last time a run it. I'm shooting fro a test and tune next weekend so a hope i can get it fixed.
[Re: JesseR]
#224530
02/14/09 05:11 PM
02/14/09 05:11 PM
Posts: 259 Canada
lenweiler
Canada
My W5's leaked before I even fired the engine. No gasget sealer. It stopped leaking after about 2-3 minutes running. Not uncommon. They stopped leaking before I gave it the sealer treatment........
Damn! I dropped my change.............
[Re: lenweiler]
#224531
02/14/09 05:19 PM
02/14/09 05:19 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I added a bottle of Bar's Stop leak...That did the trick..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: rebel]
#224535
02/14/09 06:18 PM
02/14/09 06:18 PM
since nobody has asked yet, have you backed off one bolt/stud at a time and retorqued them yet. often times that solves the problem. what was the torque # you used initially and what kind of block?
#224537
02/14/09 08:39 PM
02/14/09 08:39 PM
JesseR
Mountain City, TN
Yes, i've retorqued the studs and i'm at 90lbs with them. This is on a stock 340 block, with super smooth finishes on both the heads and block, we also drilled the rivets and sprayed coppercoat between the layers and used silicone around the water jackets. I was really hoping not to add anything, but i guess i have to. Funny thing though, they only leak when the car is running, not when the engine is cold. Thanks for the help guys, Jesse
[Re: Bob_Coomer]
#224539
02/15/09 11:55 AM
02/15/09 11:55 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats all I use... I give every rebuild a bottle even before I fire it up
[Re: MR_P_BODY]
#224540
02/16/09 08:17 PM
02/16/09 08:17 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
just wondering if you tried anything yet??, im in the same boat, very small leak on the outside of the block
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#224541
02/16/09 11:11 PM
02/16/09 11:11 PM
JesseR
Mountain City, TN
not yet, picked up a can of bars leak today, just not had time to put it in, Jesse
[Re: JesseR]
#224543
02/16/09 11:39 PM
02/16/09 11:39 PM
Stroker Scamp
pacific northwest
well then ill pick up the moroso and we'll do a test, wont fire it for a couple of days,,,,,,,ps im gonna clean everything up from below to better see if its leaking
[Re: Dustedu]
#224544
02/17/09 05:49 PM
02/17/09 05:49 PM
JesseR
Mountain City, TN
That's interesting, i did not pay attention to that, my heads are a later casting so i bet they are slotted, thanks for bringing that to my attention, Jesse
