Re: Best Way To Cut 8AN Line
[Re: cmcgee123]
#224477
02/14/09 11:55 PM
02/14/09 11:55 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
only 35.00
Nice !
but if i use those, how am i supposed to cut my fingers
Just use your second knuckle as the cut off mark, place finger on hose for length, insert both finger and hose into jaw, place bottom handle against bench, and press firmly against the upper handle with free hand. then go to wallace racing calculators to calculate potential Et savings being light one finger.
[Re: rowin4]
#224480
02/15/09 12:03 AM
02/15/09 12:03 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
Wonder how many cuts it will make before the wires start bending over before cutting off?
I use electrical tape...then make my cut with cable cutters..
[Re: Lefty]
#224486
02/15/09 02:44 AM
02/15/09 02:44 AM
Posts: 43,744 Bend,OR USA
Cab_Burge
Two or three tight raps of duct tape and the finest tooth hacksaw blade I have, put the hose in a vise and saw away A real thin cut off wheel in a high rpm(23000+ ) four inch air powered dremel or grinder works well also as already siad
[Re: rowin4]
#224490
02/15/09 08:49 AM
02/15/09 08:49 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Just don't use the one you use to wipe your
i use TP
[Re: moparniac]
#224491
02/15/09 08:51 AM
02/15/09 08:51 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I used the plier ,method on 6an and it worked great. wouldnt cut the 8 n stuff.... reason for starteting this topic..
the small one i got from HD cut my 8 AN fine.
#224492
02/15/09 09:25 AM
02/15/09 09:25 AM
Posts: 846 Long Island, NY
Cudafied
Long Island, NY
only 35.00
I don't even use tape when I use a cutter like this
[Re: moparniac]
#224495
02/15/09 12:34 PM
02/15/09 12:34 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
only 35.00
I agree also, I have a large set that can cut up to #12 with no problem.
Mike Gray
where do you get a set like that
Grainger, McMaster Carr, sometimes hardware stores will have a nice set too.
