I am running 3 Holley mechanical 2bbls on my RB mounted on an extensively ported Edelbrock intake. I need to mount a switch to trigger increased voltage to my fuel pump once the throttle is opened and the outboards start to flow.
It will be a simple circuit that grounds once the outboard throttles start to open and the fuel pump runs at max power. When they are closed the ground is open and the fuel pump runs at a reduced power level.
I'm curious if you guys might share any pictures of cleanly mounted, throttle triggered switches for Nitrous or H2O injection etc?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
