Y9# on Brodcast Sheet. What's it Mean? #2242434
01/27/17 08:05 PM
01/27/17 08:05 PM
Asheboro, NC Piedmont Triad
Quapman Offline OP
Quapman  Offline OP
I found a 72 cuda with a July 72 SPD that supposedly has "Y9#" on the bc sheet. Galen's book says it's "Show car finish". I'm a little lost on why the "#" symbol would be used instead of a number. My info is from a typed up decode that GG did and I have not seen the actual sheet. His info on the decode says "Show car finish # ?" Anyone else ever see this? Thanks.
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2242443
01/27/17 08:27 PM
01/27/17 08:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Got a photo?
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2242446
01/27/17 08:36 PM
01/27/17 08:36 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
can't account for 1972 but here's what I've got for 1971:
Y91 69-71 Show Car finish A/Less gas
Y92 69-70 Show Car Finish B/Less gas
Y93 71 Show car Finish B/ less gas
Y97 70 Show car Finish 3 gallons gas
That's all i got and I can't explain that.
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2242470
01/27/17 09:20 PM
01/27/17 09:20 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It might mean that the number was unreadable by GG - I would post a pic of it here as some of our members are scope
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2242478
01/27/17 09:36 PM
01/27/17 09:36 PM
Quapman Offline OP
Quapman  Offline OP
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2242481
01/27/17 09:41 PM
01/27/17 09:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Photo of the original?
If it was a typo on the original & then used in a decoder book that would be a bit funny.
3 & # are the same keyboard key if the caps button was bumped.
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2242488
01/27/17 09:55 PM
01/27/17 09:55 PM
Quapman Offline OP
Quapman  Offline OP
As I said, I have not seen the sheet. I thought typo, too, but "Y9#" is in his 72-4 white book and simply says "Show car finish". Y93 is Show car finish B/ Less gas.
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Morty426] #2242541
01/27/17 11:36 PM
01/27/17 11:36 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Good guess.
Y9# Show Car Finish #?
GG put a ? after the # in his decode report meaning the 3rd digit is unreadable
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: B5 Bee] #2242656
01/28/17 03:27 AM
01/28/17 03:27 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I'm betting Barry is correct - the sheet has "#" (shift 3) - the code in question should be Y93 - which is still "show car finish B/less gas" in '72
I'd also bet the decode by Galen predates the code book you are using for reference & the fact that Galen saw a sheet with "Y9#" lead GG to add that code to the following editions of the '72-'74 book
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2242678
01/28/17 09:52 AM
01/28/17 09:52 AM
Quapman Offline OP
Quapman  Offline OP
Ah yes...now that I'm fresh from a nap, it makes sense that the "#" is a typo on the sheet itself.
Now that that's "clear", what exactly is a "Show car finish"???
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2242942
01/28/17 06:28 PM
01/28/17 06:28 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Or the # merely means any one of several digits that could be the second digit in the code.
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2242950
01/28/17 06:47 PM
01/28/17 06:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Other broadcast sheet typos can be seen at http://www.hamtramck-historical.com/factoryErrors.shtml
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2242995
01/28/17 08:07 PM
01/28/17 08:07 PM
Rio Linda, CA
Rio Linda, CA
The question remains, if it's an error, is the error Galen's or the factory?
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2243016
01/28/17 08:34 PM
01/28/17 08:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Well, if the original BC says Y9# then I would guess that whatever happened started at the factory.
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2243283
01/29/17 10:16 AM
01/29/17 10:16 AM
Quapman Offline OP
Quapman  Offline OP
Beuller? Beuller?
At this point, nobody gives a crap about the typo.
What the what is "Show Car Finish"?????????
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2243295
01/29/17 11:33 AM
01/29/17 11:33 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If a factory description of it exists, I have not seen yet.
Possibly buffed?
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2243624
01/29/17 09:51 PM
01/29/17 09:51 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I had a '74 Cuda 360 that had "S/Car Finish" with a # in the box. Can't find the title at the moment.
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2243849
01/30/17 09:13 AM
01/30/17 09:13 AM
Quapman Offline OP
Quapman  Offline OP
The plot thickens!
I got a pretty decent description of "Show car finish" from my friend at FIA. I'll try to remember to post it here later. (No access to the info here)
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2243866
01/30/17 11:04 AM
01/30/17 11:04 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Guess here: Show car finish for a car that was not being delivered to a dealer (where it would be prepped for delivery). The car would be gone over at the plant to check fit and finish, cleaning, and fluids fills. These, the types of things a dealer ordinarily preforms.
Re: Y9# on Brodcast Sheet. What's it Mean? [Re: Quapman] #2243998
01/30/17 03:37 PM
01/30/17 03:37 PM
Ottawa, Ontario
Ottawa, Ontario
The plot thickens!
I for one would be interested in knowing this. Especially the difference between the show car A and B finishes and why they would put less gas for some and add 3 gallons gas for others.
