Re: sealing fan shroud to radiator? [Re: randavis] #2242884
01/28/17 03:13 PM
01/28/17 03:13 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Holy novel batman! LOL
Re: sealing fan shroud to radiator? [Re: randavis] #2242947
01/28/17 05:36 PM
01/28/17 05:36 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Vacuum advance hooked up directly to intake or a ported carb port?
Re: sealing fan shroud to radiator? [Re: BigBlockMopar] #2243169
01/28/17 11:52 PM
01/28/17 11:52 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
ported
Re: sealing fan shroud to radiator? [Re: randavis] #2244204
01/30/17 07:37 PM
01/30/17 07:37 PM
The Netherlands
The Netherlands
Could explain higher temps during idling/low rpm running.
But if you have a 'big' cam / quick ign. advance, then intake vacuum is not always an option.
Re: sealing fan shroud to radiator? [Re: randavis] #2244333
01/30/17 10:16 PM
01/30/17 10:16 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When I added my electric back-up fan I used foam to fill the gaps in. You can see a little of it in this pic. Ron
