Cragar SS wheel question
#2238541
01/21/17 05:42 PM
01/21/17 05:42 PM
Posts: 2,046 MD
RTSE4ME
MD
Do these Cragar's look like drop center type wheels? They are 1 piece aluminum direct drill so they are different than the originals. I would like to go back to 15" wheels but I have Viper brake conversion.
Re: Cragar SS wheel question
[Re: RTSE4ME]
#2238682
01/21/17 10:16 PM
01/21/17 10:16 PM
RapidRobert
pardon the novice Q but what is the drop center? Any chance of a pic of the other side (I'm assuming it is a Viper caliper fitment issue). Here's a BTT for ya since you ain't getting any love on this Q.
[Re: Cudajon]
#2238720
01/21/17 11:26 PM
01/21/17 11:26 PM
RapidRobert
for backspace flip one over from where it is in the pic & put something straight horizontally across the rim & measure down to the bolt hole area. for width measure across the rim down at the bottom of where the tire bead would seat on each side.
[Re: RTSE4ME]
#2239315
01/22/17 07:47 PM
01/22/17 07:47 PM
Posts: 25,861 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I think the OP is using the wrong terminology, "drop center" refers to the well depth in the wheel rim. (relates to tire mounting)
[Re: OzHemi]
#2239395
01/22/17 10:01 PM
01/22/17 10:01 PM
Posts: 2,046 MD
RTSE4ME
MD
And, in steel wheels... you can get outers with a deeper drop center area so that you can use (basically) a 14" wheels' center in a 15" outer. (which can interfere with caliper clearance in some cases but not all) This is what I thought a drop center wheel was, a 14" wheels' center in a 15" outer. Are Rallye Wheels drop center wheels? They will not fit with viper calipers. I have tried fitting a 15" Weld Draglite and they do fit. The cast Cragar's have a smooth lip so I thought they might work. Trying to find a old school 15" wheel for my Challenger.
[Re: RTSE4ME]
#2240800
01/25/17 01:36 AM
01/25/17 01:36 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
The 15x7s I have, they do look to go to 14" 1/2 to 2/3 of the way in. So I would say, no good for what you need.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: RTSE4ME]
#2241086
01/25/17 04:43 PM
01/25/17 04:43 PM
John_Kunkel
Rio Linda, CA
If you want the Cragar look why not try the original 2-piece SS wheels....they might have more clearance?
