Page 2 of 3 1 2 3
Re: 511 combo victor head distributor issue [Re: AndyF] #2235278
01/16/17 01:49 PM
01/16/17 01:49 PM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
That would be nice Andy. I'm going traditional. Starting to look like something.
Re: 511 combo victor head distributor issue [Re: bbodee] #2235281
01/16/17 01:55 PM
01/16/17 01:55 PM
Mt Morris Michigan
Mt Morris Michigan
Looking like I have some grinding to do.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235284
01/16/17 01:59 PM
01/16/17 01:59 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I have the pro billet also but with fab aluminum covers.I did'nt like the fit of the cast cover and HS rockers.
Re: 511 combo victor head distributor issue [Re: Clanton] #2235291
01/16/17 02:04 PM
01/16/17 02:04 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Mike C. - Which fab valve covers for your Victor heads?
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235293
01/16/17 02:05 PM
01/16/17 02:05 PM
BradH Offline
BradH  Offline
I'll have to see what mine looks like when I can mock up the top end w/ the distributor. However, I'm not expecting clearance issues because my distributor housing isn't as wide... or so I hope. whistling
Re: 511 combo victor head distributor issue [Re: BradH] #2235295
01/16/17 02:11 PM
01/16/17 02:11 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Hamburger Fab
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235319
01/16/17 02:46 PM
01/16/17 02:46 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
There is an offset NRC/INDY distributer in the for sale section for a low-deck.
Re: 511 combo victor head distributor issue [Re: HardcoreB] #2235327
01/16/17 02:57 PM
01/16/17 02:57 PM
Mt Morris Michigan
Mt Morris Michigan
thanks , I will take a look.
Re: 511 combo victor head distributor issue [Re: HardcoreB] #2235335
01/16/17 03:10 PM
01/16/17 03:10 PM
Mt Morris Michigan
Mt Morris Michigan
Do you remember what page? thanks
Re: 511 combo victor head distributor issue [Re: BradH] #2235341
01/16/17 03:18 PM
01/16/17 03:18 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Which Mike C? grin As for this Mike C, I have cheapo pro-comps. I run HS rockers like the other Mike C and like he said the rockers kinda over hang the VC rail so VC fitment can be an issue. I wanted to run studs so I had to profile the valve cover flange with a die grinder. They slide on/off with no issues now. twocents
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: 511 combo victor head distributor issue [Re: MoParFish] #2235361
01/16/17 03:35 PM
01/16/17 03:35 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thanks for posting pics!
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235377
01/16/17 04:01 PM
01/16/17 04:01 PM
Washington
madscientist Offline
Washington
I'd go with the belt drive like Andy posted.
It's clean, up and out of the way and simple.
I'm not a fan of grinding on an assembled engine.
Re: 511 combo victor head distributor issue [Re: madscientist] #2235467
01/16/17 05:41 PM
01/16/17 05:41 PM
Mt Morris Michigan
Mt Morris Michigan
It's mostly street deal. Heads are not bolted down yet.
Re: 511 combo victor head distributor issue [Re: MoParFish] #2235474
01/16/17 05:54 PM
01/16/17 05:54 PM
BradH Offline
BradH  Offline
Which Mike C? grin...
It was directed towards Mike Clanton, but your input is good, too. grin
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235491
01/16/17 06:26 PM
01/16/17 06:26 PM
Washington
Washington
Ok. I thought the pic you posted of the complete engine was yours.
Re: 511 combo victor head distributor issue [Re: MoParFish] #2235496
01/16/17 06:39 PM
01/16/17 06:39 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I didn't contour the whole rail of the vc just the corner by the dist and I only used studs on the lower so I could slid down the cover under the rocker so the stud is in the tee handle for the top holes
Re: 511 combo victor head distributor issue [Re: madscientist] #2235501
01/16/17 06:47 PM
01/16/17 06:47 PM
Mt Morris Michigan
Mt Morris Michigan
It is but the Heads are just sitting on it. Still need to check piston valve clearance.
Re: 511 combo victor head distributor issue [Re: Clanton] #2235540
01/16/17 07:55 PM
01/16/17 07:55 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
ok, ill wait til the covers get here. May get a different dist.
Doesn't Firecore offer a dist. for this issue?
I think so but will not help the valve cover on/off.What rockers?My HS stick over the seal lip.
Yes, our mechanical clears with a ton of room to adjust timing. You can also either use the stock style or male post cap. Plug in for the MSD Box as well..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 511 combo victor head distributor issue [Re: sunroofgtx] #2235770
01/17/17 12:56 AM
01/17/17 12:56 AM
Mt Morris Michigan
Mt Morris Michigan
ok, looks like I have a few options. thanks
Re: 511 combo victor head distributor issue [Re: HardcoreB] #2235800
01/17/17 01:52 AM
01/17/17 01:52 AM
Mt Morris Michigan
Mt Morris Michigan
The price was alittle out of my range for the offset distributor, but thanks any how.
Page 2 of 3 1 2 3
