Re: Brake help [Re: JohnGlenn] #2233468
01/13/17 01:29 PM
01/13/17 01:29 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Did you look at the brake math spreadsheet and find the optimum master cylinder size for those calipers?
- Stu Harmon
Re: Brake help [Re: JohnGlenn] #2234091
01/14/17 05:32 PM
01/14/17 05:32 PM
I could see a less than perfect size booster/MC causing a problem but from the descrip it sounds like there is a mechanical failure/issue somewhere. A suggestion since the booster (even if undersized) & the MC are good/bled is rehook the MC line to the front discs next to the firewall port only & bleed it out & work with them first & see if I can get it to straighten up
Re: Brake help [Re: JohnGlenn] #2234449
01/15/17 02:36 AM
01/15/17 02:36 AM
San Antonio.TX
JohnGlenn Offline OP
San Antonio.TX
So, I kind of confirmed my suspicions tonight. I eased it over to an empty parking lot right outside my neighborhood, instead of being nice I figured the best vacuum would be achieved by jumping all over it. So, I lit them up from a 20mph roll, backed off and jumped on the brakes...front end dropped and locked both front wheels up, might have locked rear also but I'm unsure. So it's settled, lack of vacuum.
Re: Brake help [Re: JohnGlenn] #2234458
01/15/17 02:51 AM
01/15/17 02:51 AM
Alright, would that be the eng not generating enough vac (wild cam) or wrong booster?
Re: Brake help [Re: JohnGlenn] #2234470
01/15/17 03:10 AM
01/15/17 03:10 AM
San Antonio.TX
San Antonio.TX
I'm banking on engine. It's a 318 punched to a 393, hughes HYD roller 236/242 duration with 568/560 lift, 11:1 compression, worked iron 2.02/1.60s, matched air gap topped off with an 850 Holley. So, not real good vacuum.
Re: Brake help [Re: JohnGlenn] #2234473
01/15/17 03:15 AM
01/15/17 03:15 AM
San Antonio.TX
San Antonio.TX
And it's only going to get worse. I've got a set of fully worked w5s and a matched single plane just waiting to go on, so, my vacuum predicament isn't going to get better.
Re: Brake help [Re: JohnGlenn] #2234485
01/15/17 03:51 AM
01/15/17 03:51 AM
I ain't into PB but iirc someone (on here) said that either 12 or 14 in hg is needed for good functioning. If that ain't available, is there a booster type that will function with less? Or maybe a vac pump.
Re: Brake help [Re: RapidRobert] #2234496
01/15/17 04:53 AM
01/15/17 04:53 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Hydro boost, albeit a bit too non period correct looking for me. That is if low vacuum should prove to be the problem. I would myself prefer to go non-power brake in that case.
Re: Brake help [Re: Sxrxrnr] #2234600
01/15/17 01:11 PM
01/15/17 01:11 PM
that'd be my choice (even with adequate vac): less weight/better brake feel/simpler system/more room. EDIT From what I understand PB does not give increased braking, it just requires less leg effort for the input side.
Re: Brake help [Re: JohnGlenn] #2234833
01/15/17 06:43 PM
01/15/17 06:43 PM
San Antonio.TX
San Antonio.TX
The car isn't factory correct, and I don't mind. If it were a 70-71, I would care, but being a 73 it's subject to my whims. What I want is a solidly streetable car, something you drive like a new car, something that's not laborious to drive. Most of you know what im talking about. I want to Friday night cruise without the pucker factor. I, like many car guys, love my ride, but I don't trust it when traffic gets hairy. I've already started down the pro touring line, now it's time to commit.
