Re: Challenger Upper Cowl [Re: 1971 Gran Coupe] #2234510
01/15/17 08:30 AM
01/15/17 08:30 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By 1971 Gran Coupe
70's had screw on as well as 71's. It may have been a mid to late year change from screw to clip on in 71, but my two 71's have the screw type cowl.
All 70s have screws. Early 71s have screws and late 71s have the clip in type.
Re: Challenger Upper Cowl [Re: screamindriver] #2234688
01/15/17 02:55 PM
01/15/17 02:55 PM
Maryland
glenngomango Offline
Maryland
It's possible no numbers on the rad core support, but I would look again where the top of the radiator corner mounts closest to the drivers side, where the yellow rad sticker usually is. Hard to see with the rad mounted because it is usually not stamped on the top rather facing the rad. Sand off the paint in this area if you want to be sure. Hamtramck cars as well as LA e bodies are similar:)
