Re: At what point is 4130 worth it??
[Re: polyspheric]
#2230659
01/09/17 07:25 AM
01/09/17 07:25 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
BTW: mild is 33% stiffer (resistant to bending, twisting, and intrusion) than moly because of the thicker wall. Is it really so? I have bended both with a manual bender, and it definitely felt like the moly needed at least the double force to bend.
Plynouth VIP '67 TT IC EFI
[Re: Monte_Smith]
#2230662
01/09/17 08:11 AM
01/09/17 08:11 AM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
It wont meet 25.5 with steel. Since when?? No cage with a mild steel hoop will cert quicker than 8.50. A 25.5 cert is good to 7.50 That is BS, just check the actual spec manual for both 25.4 and 25.5 and it's clear that mild steel is permitted. I know of several 7.50 cert cars constructed with 100% mild steel, some 25.4 and some 25.5, not recommending it, but it is certainly doable
[Re: DemonDust]
#2230677
01/09/17 10:01 AM
01/09/17 10:01 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
If you are upgrading from a 10 point, and grudge racing, then I would recommend C/M. It will help keep additional weight to a minimum, maybe even lighter, and as stated, helps resale value.
[image][/image]
[Re: Monte_Smith]
#2230695
01/09/17 11:32 AM
01/09/17 11:32 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
It wont meet 25.5 with steel. Since when?? No cage with a mild steel hoop will cert quicker than 8.50. A 25.5 cert is good to 7.50 I thought you can go 7.50 with mild steel...
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: dthemi]
#2230705
01/09/17 11:58 AM
01/09/17 11:58 AM
Posts: 10,046 MN
JERICOGTX
MN
I totally understand CM is the only choice for a light drag car. The funny thing to me is NASCAR are all MS. There isn't an issue with weight for them given how much they have to weigh. Still if CM were better at impact, they'd build from that, and hang weight I think. Land Speed racing does not care for Moly either. Again, weight isn't a issue, but they feel mild steel is safer.
69 GTX
68 Road Runner
[Re: DemonDust]
#2230742
01/09/17 12:51 PM
01/09/17 12:51 PM
Posts: 4,211 New York
polyspheric
New York
For a light car, CM obviously saves weight, but at what cost per lb. saved?
Boffin Emeritus
[Re: polyspheric]
#2230747
01/09/17 01:00 PM
01/09/17 01:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I buy steel by the pound.. X length per pound.. yes moly is a bit more than mild but a moly cage is one of the easiest ways to loose weight.. and for the cost difference it not bad.. like anything else.. look around for pricing... I finally found a place that has good pricing.. but I pick it up.. and I was buying 24' sticks of it
[Re: dthemi]
#2230779
01/09/17 01:52 PM
01/09/17 01:52 PM
Posts: 22,724 Bitopia
jcc
Bitopia
I totally understand CM is the only choice for a light drag car. The funny thing to me is NASCAR are all MS. There isn't an issue with weight for them given how much they have to weigh. Still if CM were better at impact, they'd build from that, and hang weight I think. I think the main safety issue for Nascar is MS/welds are much more forgiving with multiple impact loads, something Nascar has to contend with at 200 mph speeds on a walled race track with 40? other nearby cars on the track, besides the cost and ease of repair.
[Re: jcc]
#2230820
01/09/17 02:53 PM
01/09/17 02:53 PM
MR_P_BODY
Being that they have to weigh 3450 min its much easier to get NEAR that weight.. and all the side bars that they have.. it gets them closer to the weight but still allows for weight to be put in where they need added weight.. plus the fact that they do get hit on a regular basis its easier and cheaper to rebuild any part of the car.. I use to fix some of the local roundy round cars near me... some guys use to fix their cars right at the track since its migged and could be fixed quickly
[Re: DemonDust]
#2230872
01/09/17 04:06 PM
01/09/17 04:06 PM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
NASCAR stuff is DOM tubing, 1.75-inch diameter, .090-in. wall - usually center-less ground - not cheap stuff either. The reason I have always been told is "it has always been that way" and two it is much easier to make repairs to a twisted up chassis
[Re: DemonDust]
#2230882
01/09/17 04:21 PM
01/09/17 04:21 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
As stated always best to go that way. Also mild steel is only good to 25.4 and 7.50 cert. One reason the Cuda is gone, mild steel car. Also as stated Nascar uses DOM steel, way stronger and heavier than std mild steel.
[Re: DemonDust]
#2230916
01/09/17 05:33 PM
01/09/17 05:33 PM
Posts: 11,694 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Drag racing vs. stock cars vs. land speed racing = apples, oranges and tangerines.
Both may be called "mild steel" but there is a big difference between 1010ERW and 1020DOM.
25.4 and 25.5 (8.49 to 7.50 spec) can use mild steel of the correct thickness and ASTM requirements. Why anyone would is the question. 25.1 or anything quicker than 7.50 has to be 4130 or Docol
Mild steel has it's place. A person who wants to build their own 11 or 10 second car in their home shop, on a budget, with a MIG machine, should be able to do that. Beyond that, using MS makes less sense.
[Re: DemonDust]
#2231113
01/09/17 09:49 PM
01/09/17 09:49 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Road racing specs have all but banned CM in the heavier cars because of the possibilities present in that environment. CM has a tendency to Crack and break and when the possibility of of being hit in the driver's door is high that is unacceptable. DOM absorbs more.
Mopar to the bone!!!
[Re: jyrki]
#2231158
01/09/17 10:41 PM
01/09/17 10:41 PM
Posts: 8,344 fredericksburg,va
cudaman1969
fredericksburg,va
BTW: mild is 33% stiffer (resistant to bending, twisting, and intrusion) than moly because of the thicker wall. Is it really so? I have bended both with a manual bender, and it definitely felt like the moly needed at least the double force to bend. I bent a test 90% 120 wall dom mild steel last nite, thought I was going to have a hernia. Bent some CM later and much easier to bend, both 1 5/8. I think I'm going to invest in the hyd add on to my bender, I ain't getting any younger.
[Re: DemonDust]
#2231217
01/09/17 11:45 PM
01/09/17 11:45 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Increasing the diameter of the tube is more effective at increasing strength than increasing the thickness. Design of the chassis, (proper placement of bars and use of diagonals) is the most important aspect of a safe car, not what it's made of. Given 2 cars that are considered to be equally safe, however that is determined, I will always chose the lighter option.
