Re: Anyone use(d) the Corvette L88 air cleaner base?
[Re: BradH]
#2227148
01/04/17 03:24 PM
01/04/17 03:24 PM
Thumperdart
State of confusion
More than fitment, I'd be concerned w/flow path but maybe it has little affect OR, a lot which makes a WB readout w/different changes fun and info is gained both good and bad..........
[Re: Thumperdart]
#2227151
01/04/17 03:29 PM
01/04/17 03:29 PM
Posts: 3,855 N.E. Ohio
6bblFLASH
N.E. Ohio
I use an aftermarket version on my 1050cfm 4150 style Holley. Small supercharger under it. Runs the same with or without.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: Thumperdart]
#2227182
01/04/17 04:31 PM
01/04/17 04:31 PM
BradH
More than fitment, I'd be concerned w/flow path... Here's a cross-section of the Braswell air cleaner that's a 14.25" base and 15.25" top IIRC) so that the filter tilts away from the walls of the base. It also requires a spacer to raise the base above the fuel-level adjustment screws. Not sure if this is one for their 4825 or 4760 carbs. Also, no data on their web site as to how much the air cleaner sits above the carb flange, though... looks pretty tall for a drop-base setup.
[Re: BradH]
#2227193
01/04/17 04:46 PM
01/04/17 04:46 PM
Thumperdart
State of confusion
Notice the taper on the lid to channel air down it's throat..........
[Re: BradH]
#2227194
01/04/17 04:50 PM
01/04/17 04:50 PM
Posts: 1,567 Ky
jt4406
Ky
The crankcase vent tube on the passenger side rear of original gm bases interferes with a double pumper rear accelerator pump mechanism, I believe they addressed this on the repops(?). Also I don't think it will sit down on a generic chrome "dual line" fuel line, you may have to run the factory GM style "Y" block and 5/16 fuel lines (fuel block to bowls), although you may be able to bend a chrome one down enough to clear.
I think the big issue will be how it sits down over the accelerator lever rod that sticks out toward the driver side fender, you may be able to eliminate it on a std trans car, but an automatic.....??? Just a little FYI from a former bowtie fan.
jess
Yeah, it's hopped up to over 160...
[Re: jt4406]
#2227198
01/04/17 04:54 PM
01/04/17 04:54 PM
BradH
The reproduction I was looking at said "no breather tube on base". Here's the current fuel line setup, but no pictures handy showing the throttle linkage side. The car has a manual valve body auto, so there's no kickdown linkage to get in the way.
[Re: BradH]
#2227268
01/04/17 07:17 PM
01/04/17 07:17 PM
Posts: 1,509 TN
SCATPACK 1
TN
Brad Who made or where did you get the bracket that holds the pressure regulator. Nice looking piece.
Old Geezer Racing
[Re: SCATPACK 1]
#2227299
01/04/17 07:51 PM
01/04/17 07:51 PM
BradH
Brad Who made or where did you get the bracket that holds the pressure regulator. Nice looking piece. Jeg's; they offer them for a variety of brands of regulators.
[Re: justinp61]
#2227329
01/04/17 08:37 PM
01/04/17 08:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont like drop base air clearers.. they change the direction of the air(restriction) but if you have to use them then you have no choice... just remember ALL air cleaners are a restriction.. I did a few years testing air cleaners for Chrysler
[Re: BradH]
#2227577
01/05/17 02:18 AM
01/05/17 02:18 AM
Posts: 5,179 CT
GTX MATT
CT
I was running a spectre 3 inch drop base for a long time on my car. I went to a Moroso flat bottom to install a fuel pressure regulator mounted on the bracket like you have. I didnt actually install the regulator yet, just made sure I had room and its been sitting on the shelf since haha.
Anyway, my old one put the lid pretty close to the bowl vents/choke tower. I did notice a difference in how much I had to slip the clutch. Also it was pretty hard to really smoke the slicks when I dumped the clutch before, itd spin them and go. A 3k dump just ROASTS them now. It doesnt feel like I picked up crazy horsepower but the car is more responsive.
Also, with the flat bottom I could only fit a 2 inch filter, but the lid is still about an inch higher than it used to be. Ordered an RO23 scoop so I can run a taller filter, but wont be in for a few weeks.
[Re: MR_P_BODY]
#2227693
01/05/17 12:39 PM
01/05/17 12:39 PM
Posts: 4,811 Wichita
GY3
Wichita
I dont like drop base air clearers.. they change the direction of the air(restriction) but if you have to use them then you have no choice... just remember ALL air cleaners are a restriction.. I did a few years testing air cleaners for Chrysler I did back to back testing at the track this summer. A K&N filtered drop base aircleaner vs. no aircleaner at all. Identical 11.41 times and mph with and without.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
