Page 2 of 3 1 2 3
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: GY3] #2227704
01/05/17 11:56 AM
01/05/17 11:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By GY3
Originally Posted By MR_P_BODY
I dont like drop base air clearers.. they
change the direction of the air(restriction)
but if you have to use them then you have no
choice... just remember ALL air cleaners are
a restriction.. I did a few years testing air
cleaners for Chrysler
wave
I did back to back testing at the track this summer. A K&N filtered drop base aircleaner vs. no aircleaner at all. Identical 11.41 times and mph with and without.
All you people say I didnt see any change.. did
you start changing jets to optimize without...
no... you took it off and didnt see a change..
because you were jetted with it on
If you have the room.. put a ideal entry on it
and see what happens.. you WILL be adding fuel
wave
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: GY3] #2227715
01/05/17 12:12 PM
01/05/17 12:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
wave
Try that w/a sealed scoop and get back w/us........
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: GY3] #2227766
01/05/17 01:13 PM
01/05/17 01:13 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
wave
I had the same results as you. I am under the stock hood and it made no difference. I did the same test with EFI and it didn't matter. I have not tried it with the bigger motor yet though.
68 Barracuda Formula S 340
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: Thumperdart] #2227917
01/05/17 03:46 PM
01/05/17 03:46 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
wave
Made the pan for this summer already..
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: GY3] #2227943
01/05/17 04:35 PM
01/05/17 04:35 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Well my wide-band didn't see the difference, so I am sticking with my opinion.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: 6bblFLASH] #2227996
01/05/17 05:43 PM
01/05/17 05:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Then your seeing turbulence over the carb..
I will say it again ALL filters are a restriction
and its a proven fact... just because you didnt
see any change DOESNT change the FACT that a filter
isnt a restriction...
wave
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: MR_P_BODY] #2228014
01/05/17 05:56 PM
01/05/17 05:56 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
wave
The real question is, is the restriction offset by the straightening/smoothing ot the airflow into the carb?
How much HP difference, on average, did your testing show?
Was it dynamic, real world testing or in a dyno cell?
'63 Dodge 330
11.19 @ 121 mph
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: GY3] #2228021
01/05/17 06:05 PM
01/05/17 06:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
This was on a filter flow bench... also just like guys
say that the filter top is better... I've done that type
of filter on the bench and at the track.. that top hurt
power... I have one right now but I put a plastic cover
over it.. reason why.. the 2 directions of air flow
hurt the total flow.... BUT you guys do what you want
wave
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: GY3] #2228027
01/05/17 06:11 PM
01/05/17 06:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
wave
thumbs
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: MR_P_BODY] #2228029
01/05/17 06:12 PM
01/05/17 06:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
wave
On the same note, they also smooth out airflow apparently.......... work
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: Thumperdart] #2228036
01/05/17 06:20 PM
01/05/17 06:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Very well could be but that doesnt change the
FACT that ALL FILTERS ARE A RESTRICTION.. if
you have the space put on a ideal entry and
try it
wave
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: BradH] #2228049
01/05/17 06:41 PM
01/05/17 06:41 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I had to have a drop base air cleaner to clear my hood scoop after building my 434 last year. When I dynoed it the guys at the shop were asking me about my set up and I mentioned that I thought I was going to need a drop base air cleaner. They recommend the one in the link I posted and said it made more power than any other air cleaner that they had dynoed.
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: justinp61] #2228053
01/05/17 06:48 PM
01/05/17 06:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok... I quit... filters are GREAT.. they arent any
restriction
wave
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: BradH] #2228059
01/05/17 06:56 PM
01/05/17 06:56 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mike pleas re read what I posted. They didn't say it made more power than NO air cleaner. It made more power than ANY AIR CLEANER they had tested.
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: MR_P_BODY] #2228062
01/05/17 06:59 PM
01/05/17 06:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
wave
try it
wave
I hear ya Mike it's just a b$%^h to street drive and not give something up unfortunately to keep debris outta the motor. K&N apparently did some dragster/pro stock scoop filters but never really heard the results........
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: MR_P_BODY] #2228113
01/05/17 08:13 PM
01/05/17 08:13 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
restriction
wave
They might. I just haven't seen enough restriction to warrant removing the filter. Especially when I race at a lot of tracks where we park on dirt/grass.
No need to get pissy. Just sharing my personal testing and results... shocked
'63 Dodge 330
11.19 @ 121 mph
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: GY3] #2228127
01/05/17 08:28 PM
01/05/17 08:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looking back, my car was .10 quicker w/the hood/sealed pan on than off in the 1/8th...............and 1 mph...........fwiw........
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: MR_P_BODY] #2228156
01/05/17 08:58 PM
01/05/17 08:58 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
restriction
wave
That's NOT what he said. In some racing, dirt cars for instance, you MUST run an air cleaner. If the shop Justin was using does a lot of dirt car motors, they test those type things. At least that's what I took from the post
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: justinp61] #2228161
01/05/17 09:04 PM
01/05/17 09:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And this was his other post Monte... as I said
EARLY in this.. if you have to you have to..
still doesnt say its NOT a restriction.. which
I STAND BY
wave
Re: Anyone use(d) the Corvette L88 air cleaner base? [Re: MR_P_BODY] #2228173
01/05/17 09:21 PM
01/05/17 09:21 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I STAND BY
wave
A couple of us have quantified our results with real world data to back it up...
Just because you use words like "FACT" and "RESTRICTION" doesn't make it so in every case.
'63 Dodge 330
11.19 @ 121 mph
Page 2 of 3 1 2 3
