Updated! Dip tube for degreasing, de-rusting a driveshaft?
#2226496
01/03/17 07:06 PM
01/03/17 07:06 PM
Posts: 29,648 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
It seems like a 4" PVC pipe with one end cap would fork fine, but I wonder if the glue would hold up? I'd rather ask before I do something that leads to a huge mess, so what have you done that worked? Thanks.
Re: Dip tube for degreasing, de-rusting a driveshaft?
[Re: Alaskan_TA]
#2226745
01/03/17 11:42 PM
01/03/17 11:42 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I use a 2 incher for my e-brake cables with no issue.
Careful, your character's showing!
[Re: Alaskan_TA]
#2226830
01/04/17 12:57 AM
01/04/17 12:57 AM
Posts: 1,651 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Your driveshaft will probably float in Evapo-Rust or water with the top end sticking above the liquid, so you will need to find a way to keep it completely submerged to get de-rusting all over.
When finished with the rust removal, you'll likely have rust pitting on the tube. This is the norm for almost-50-year-old drive shafts.
If you want a factory fresh drive shaft, where the original end castings are gouged off and new tubing welded on, this guy was at Carlisle 2016 and apparently does excellent work from the looks of the driveshaft he had on display:
Rob Brombacker, (734) 564-3856, rbrombacker at specproj.com
He told me that he keeps his own driveshaft looking like new by painting or spraying a solution of Cosmoline thinned about 50-50 with mineral spirits about once per year. This was what he said when I asked him if he used RPM. Here in Houston with high humidity and 50 miles from the Gulf, I will probably use both on bare steel parts.
[Re: kentj340]
#2226929
01/04/17 04:59 AM
01/04/17 04:59 AM
Posts: 1,922 Medina, Ohio
HEMICUDA
Medina, Ohio
He told me that he keeps his own driveshaft looking like new by painting or spraying a solution of Cosmoline thinned about 50-50 with mineral spirits about once per year. This was what he said when I asked him if he used RPM. Here in Houston with high humidity and 50 miles from the Gulf, I will probably use both on bare steel parts. He's doing one for my AAR right now, he's as good as it gets if you're looking for perfect OEM.
[Re: Alaskan_TA]
#2228221
01/05/17 10:58 PM
01/05/17 10:58 PM
Posts: 1,080 Long Island, NY
70plymA34
Long Island, NY
what has everyone done to bring back the shiny steel look. also does reheating the welds give them that new appearance. I remember this was discussed a while back. I would be looking for a way that does not involve paint. mine is not that badly pitted
Super Commando
[Re: 70plymA34]
#2229118
01/07/17 02:08 AM
01/07/17 02:08 AM
kentj340
Cut and Shoot, TX
bring back the shiny steel look I tried scrubbing with several grades of steel wool and oil. It didn't work. Looks like a more aggressive approach would be better, maybe #600 paper with oil and working up with finer grits?
[Re: Alaskan_TA]
#2230770
01/09/17 01:42 PM
01/09/17 01:42 PM
Posts: 7,358 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Burdar - that drive shaft looks great!. I assume you used maybe 4" PVC pipe with a hard cap on one end, put the shaft in, put assembly upright, then flooded with Evaporust while weighting the shaft with the brick? Yes, a 5' section of 4" PVC with a cap on one end. The shaft in the picture was 3.5" in diameter so there isn't much extra space between the PVC and the shaft. It doesn't take much EvapoRust to fill the tube. I would suggest trying to find a cap that has a threaded plug in the end. It would make draining the tube much easier. I actually used vinegar to take the majority of the rust off this time. The EvapoRust was used last to keep the shaft from flash rusting. I sprayed some WD-40 on it for protection while it's stored. It still needs to be cut to length for use on my project. As far as getting a more original look, I've watched a few Youtube videos where they sand the shaft with emery cloth while it's spinning on the balancer. That might get it close...
[Re: burdar]
#2231384
01/10/17 02:37 AM
01/10/17 02:37 AM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Burdar - that drive shaft looks great!. I assume you used maybe 4" PVC pipe with a hard cap on one end, put the shaft in, put assembly upright, then flooded with Evaporust while weighting the shaft with the brick? Yes, a 5' section of 4" PVC with a cap on one end. The shaft in the picture was 3.5" in diameter so there isn't much extra space between the PVC and the shaft. It doesn't take much EvapoRust to fill the tube. I would suggest trying to find a cap that has a threaded plug in the end. It would make draining the tube much easier. I actually used vinegar to take the majority of the rust off this time. The EvapoRust was used last to keep the shaft from flash rusting. I sprayed some WD-40 on it for protection while it's stored. It still needs to be cut to length for use on my project. As far as getting a more original look, I've watched a few Youtube videos where they sand the shaft with emery cloth while it's spinning on the balancer. That might get it close... [b][/b] Yeah, but the Sand Scratch Police will ding you for the grain running the wrong way.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
