Re: Nice valley pan for low deck?
[Re: viperblue72]
#2223611
12/30/16 09:08 PM
12/30/16 09:08 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
AndyF has them. Check the trick flow head thread for pics of it.
[Re: viperblue72]
#2223727
12/31/16 12:02 AM
12/31/16 12:02 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Send AndyF a PM, he makes them.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: viperblue72]
#2223774
12/31/16 01:13 AM
12/31/16 01:13 AM
Posts: 31,105 Oregon
AndyF
Where can I purchase one of these and is there a part number? RB version is AR182A, low deck is AR300A. You have to include the A at the end or else you'll get the regular Indy style valley plate with the removable center section. I don't have the new plates on my website yet but I have them in stock so Hughes and Mancini can order them. I'm just behind on my website maint. It is easier for me to invent new stuff than it is to update the website.
[Re: fast68plymouth]
#2224910
01/01/17 05:08 PM
01/01/17 05:08 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Uuuummmm, did you not see the pic? Yep, sure did and it don't look like a standard head to me. It's aftermarket aluminum. When referring to a standard head I think 906, 915, 452, etc..... Anything else I call it out by name.
[Re: viperblue72]
#2224913
01/01/17 05:10 PM
01/01/17 05:10 PM
AndyF
I solved that problem by designing the batwings. They will seal an OEM head also although the job is easier on an aftermarket head.
[Re: AndyF]
#2224917
01/01/17 05:16 PM
01/01/17 05:16 PM
roadhazard
Akron, Ohio U.S.A.
I solved that problem by designing the batwings. They will seal an OEM head also although the job is easier on an aftermarket head. Gotcha! ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) That will certainly work! I made plates for mine back in the day to cover up a machining error. They have worked out well.
[Re: AndyF]
#2224940
01/01/17 05:49 PM
01/01/17 05:49 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
To be fair, the batwings are only 0.032 thick so I don't know how long they would hold up on a stock head. The exhaust gas crossover gets really warm on those heads so I bet it would eat thru the aluminum eventually. Not if there is no heat crossover in the intake manifold.
[image][/image]
[Re: viperblue72]
#2224942
01/01/17 05:51 PM
01/01/17 05:51 PM
fast68plymouth
So. Burlington, Vt.
Greg, I try to keep the erroneous info down to a minimum ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: viperblue72]
#2225091
01/01/17 09:47 PM
01/01/17 09:47 PM
Posts: 5,169 CT
GTX MATT
CT
Itd be nice if someone besides fel pro made the factory style tins, and it actually fit. Victor, SP, its all Fel Pro in a different box. The fel pro has small ports and is baaically flat. I found an NOS Chrysler one a few months back and used it, it fit so much better than the fel pro. Cough Greg Cough...
