Surface Treatment #2222871
12/29/16 05:08 PM
12/29/16 05:08 PM
Great Neck,LI,new york
hemi-itis Offline OP
http://www.wpctreatment.com/
Has anyone used their service? My mamma also told me when something sounds too good to be true is normally is NOT! But there is always exceptions work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Surface Treatment [Re: hemi-itis] #2223011
12/29/16 10:39 PM
12/29/16 10:39 PM
That treatment sounds like micro polishing that has been used in Hi Po motors and drive train parts for a long time shruggy scope
Re: Surface Treatment [Re: hemi-itis] #2223020
12/29/16 10:59 PM
12/29/16 10:59 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Sounds similar to this process.
http://www.microblueracing.com/
They treat big truck engine and drivetrain parts with it and people I've spoken to that use it claim it reduces hub temps on wheel ends and reduced oil temps in trans and diffs as well as engine. This would imply reduced friction.
NASCAR teams use it so there must be something to it.
Kevin
Re: Surface Treatment [Re: hemi-itis] #2223264
12/30/16 11:55 AM
12/30/16 11:55 AM
Read the testimonials on the site,but would like to talk with some people that used it.It's not like I can Call Roy Johnson!
Re: Surface Treatment [Re: hemi-itis] #2223267
12/30/16 12:04 PM
12/30/16 12:04 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Dura Lube, Motor Up, Prolong, z max, Slick 50 and what ever other crap can be added to the pile of snake oil
Re: Surface Treatment [Re: The Shadow] #2223383
12/30/16 03:12 PM
12/30/16 03:12 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Except it isn't oil or anything else that pours out of a bottle.
Kevin
Re: Surface Treatment [Re: Twostick] #2223387
12/30/16 03:18 PM
12/30/16 03:18 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Kevin
No it isnt but makes the same claims and they have been proven to be bogus
Re: Surface Treatment [Re: hemi-itis] #2223396
12/30/16 03:31 PM
12/30/16 03:31 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No they haven't. Again, this is NOT an additive. This is basically micro polishing, which does work. Racers pay thousands of dollars for low drag wheel bearings, center sections and the like. The difference, the parts are micro polished and it DOES make a difference.
Now, is it worth it for the OP? Can about guarantee NO
Re: Surface Treatment [Re: hemi-itis] #2223398
12/30/16 03:37 PM
12/30/16 03:37 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I read it as a 1 micron coating not a polishing.
I agree on micro polishing but not on coatings
Re: Surface Treatment [Re: hemi-itis] #2223400
12/30/16 03:42 PM
12/30/16 03:42 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Just Google Johnson & Johnson Racing Greeneville TN.
Phone number pops right up on YP.
AJ has posted here before and comes across as pretty down to earth. If it isn't top secret, somebody there can probably tell you what they use it on and what the benefit is.
Kevin
Re: Surface Treatment [Re: The Shadow] #2223463
12/30/16 05:06 PM
12/30/16 05:06 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Years go I got some Techline coating Powerkote WSX lubricant that coated new parts
Re: Surface Treatment [Re: Clanton] #2223509
12/30/16 06:19 PM
12/30/16 06:19 PM
dogdays Offline
dogdays  Offline
It's not a coating!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Take the time to study the website before spouting off.
It is, as Monte said, micropeening. The claims to create a harder and smoother surface are not claims that fit with a coating, unless we're talking about diamond-like coating whch is used extensively in NASCAR and other pro racing venues.
The smooth surfaces found on things like intake manifolds are obtained by ball burnishing, which uses larger diameter, softer balls.
R.
From the WPC website:
"WPC is a proven process that has been utilized for many years in the racing and automotive industry. WPC is not a coating, it is a treatment that enhances the surface to reduce friction and strengthen engine parts.
Image of WPC Treatment
WPC achieves this process by firing ultra fine particles towards the surface of a product at very high speeds. The resulting thermal discharge permanently changes the surface, strengthening structure and creating a harder more durable final product.
Media Size and Speed
Shot peening (left) and WPC (right)
Why is WPC Superior?
The WPC process is unrivalled in treating engine parts and other surfaces that have contact points of friction. WPC is superior because it is not a coating; it is a permanent surface treatment that reduces friction while strengthening the part. It's unique micro-dimple formation pattern greatly reduces friction and is unmatched by conventional methods of surface treatment.
WPC has the capacity to treat carburized, nitrided and plated parts without noticeable dimensional changes, and, upon completion of treatment, no further modifications are required of the parts. The strength and durability improvement on the surface after the WPC treatment is unsurpassed by any current methods.
Treatable products include steel, aluminum, titanium, copper and brass and soft surfaced bearings. WPC can treat any metallic item in a disassembled state."
