Re: Bb cam retainer?
[Re: mopar dave]
#2222766
12/29/16 02:12 PM
12/29/16 02:12 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Dave, there is no cam retainer on BB/Gen II Hemi .Basically the chain and the OP drive keep it in place. You can fit a cam button on the chain sprocket end there that butts up against the timing cover if desired, and is a fairly common install on some more serious builds. My .02 Hope this helps.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
[Re: mopar dave]
#2222786
12/29/16 02:39 PM
12/29/16 02:39 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
The valve spring pressure and the taper on the cam lobes on a flat tappet cam is what keeps the cam in the block. Roller cams have flat lobes which require the cam button to keep the cam from "walking" in the block.
68 Charger R/T 440 auto
[Re: wesgtx440]
#2222822
12/29/16 03:28 PM
12/29/16 03:28 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
The valve spring pressure and the taper on the cam lobes on a flat tappet cam is what keeps the cam in the block. Roller cams have flat lobes which require the cam button to keep the cam from "walking" in the block. Also the oil pump drive helps push the cam back towards the tranny, I think
[Re: mopar dave]
#2222985
12/29/16 09:47 PM
12/29/16 09:47 PM
Cab_Burge
The stock three bolts motors came with no washers I've never thought of using them due to how close the bolt heads can be to the cover Blue Loctite and 35 Ft Lbs. you should be golden
