400 stock stroke pistons #2222549
12/29/16 12:49 AM
12/29/16 12:49 AM
Spencer NY
killermopar Offline OP
Spencer NY
Hey guys. I know everybody likes strokers and big cubes ect. And I do too. I want to build a 400 with a turbo. I'm using a clean 400 block, a 383 crank, h beam rods, but I'm hung up on pistons. I need a forged slug around 9 to 1. Does anyone know of any? I've seen a lot of hypereutectic and cast, but not much on forged. Any help is appreciated. Thank you.
Re: 400 stock stroke pistons [Re: killermopar] #2222559
12/29/16 01:12 AM
12/29/16 01:12 AM
AndyF Offline
AndyF  Offline
If you have a credit card you can get pistons, they are just a phone call away.
You might consider using a longer rod since then you won't need such a tall piston.
Re: 400 stock stroke pistons [Re: killermopar] #2222564
12/29/16 01:29 AM
12/29/16 01:29 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Would you not be money ahead to do a 451? Those parts are very common and ICON makes dished pistons.
Re: 400 stock stroke pistons [Re: killermopar] #2222565
12/29/16 01:30 AM
12/29/16 01:30 AM
Spencer NY
Spencer NY
I get what your saying Andy. What combination would you suggest?
Re: 400 stock stroke pistons [Re: killermopar] #2222574
12/29/16 01:43 AM
12/29/16 01:43 AM
Spencer NY
Spencer NY
I also thought about that too. I'm going price that out also. I'm also not opposed to good used parts. I'm always looking around. I just want something I haven't done before.
Re: 400 stock stroke pistons [Re: killermopar] #2222588
12/29/16 02:17 AM
12/29/16 02:17 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Diamond will usually give you one free change to off the shelf pistons. They sell a .035+ 400 piston that they can probably modify the compression height to bring compression down.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 400 stock stroke pistons [Re: A39Coronet] #2222598
12/29/16 02:29 AM
12/29/16 02:29 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
If you use a 1.32 CH piston with a -12.5cc dish and a factory iron head you would be around 9:1 with diamond shelf pistons.
This one might work too:
https://www.uempistons.com/index.php?mai...0c35ef4f98f6b6e
Of course this is all for a 451 i.e. 400 w/ a 400 journal sized 440 crank and a 6.76" (stock 440) rod.
Re: 400 stock stroke pistons [Re: killermopar] #2222600
12/29/16 02:34 AM
12/29/16 02:34 AM
AndyF Offline
AndyF  Offline
I did a stock stroke 400 a long time ago with Hemi rods and shelf stock stroker pistons. That engine worked really well. Ran high 10's in a street car with full exhaust, full interior, street tires, etc.
Re: 400 stock stroke pistons [Re: AndyF] #2222625
12/29/16 03:35 AM
12/29/16 03:35 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Is it a must to have forged..I have a fresh low deck 400 stock build heads cut I'd like to turbo sometimes down the road ..got a holeset55 off a Cummins not looking to set the world on fire but to learn go from there ..turbo makes 400 and 1250 on Cummins..
Re: 400 stock stroke pistons [Re: AndyF] #2222628
12/29/16 03:51 AM
12/29/16 03:51 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Um, would you care to share all of the details of this?
Heads, cam, intake/carb, Converter, gears? Car weight?
Wow...
A shelf piston?
Re: 400 stock stroke pistons [Re: killermopar] #2222768
12/29/16 02:17 PM
12/29/16 02:17 PM
AndyF Offline
AndyF  Offline
Ported RPM heads, Victor 383 intake, 750 DP carb, small Ultradyne solid roller. I don't recall the gears, probably 3.90 since it had a 8 3/4 rear end. It was a '72 Duster with full interior, full exhaust, street tires. Ran 10.90's a bunch of times until it was kicked off the track since he didn't have a roll bar.
Yes, a shelf piston fits just fine with the long rod. I think we used a piston with a CH of 1.32 and then decked the block a small amount. Don't recall the part number but it was a JE dome piston with a 0.990 pin. The trick part was the connecting rod. It was a Manley rod that was Hemi + 0.100 with Mopar big end and 0.990 small end. Super nice rod that Manley made for a few years.
Re: 400 stock stroke pistons [Re: killermopar] #2222773
12/29/16 02:24 PM
12/29/16 02:24 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looks like it would need about a 1.43c/h with a 6.86 rod and stock stroke.
For the price of a crank, I'd just build something bigger myself.
An Icon 829(1.423c/h) would work if you can find a 6.86 rod with a .990 small end.
Re: 400 stock stroke pistons [Re: killermopar] #2222796
12/29/16 02:53 PM
12/29/16 02:53 PM
Spencer NY
Spencer NY
Maybe this is stupid...what about a 440 piston meant for a stroker? I like the RPM capability that a short stroke big bore provides, and for boost I think it would be ideal.
Re: 400 stock stroke pistons [Re: killermopar] #2222799
12/29/16 03:00 PM
12/29/16 03:00 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Molnar makes a 6.86 rod with mopar big end and chevy pin size. If my math is correct you could use a 4.375 stroker piston for a 440. +030 is .008 overbore so possibly the 0.040 or 0.055 version could be used depending on the block.
9.98(DH) - 6.86(rod) - 1.423(IC829 CH or IC843 depending on CR) - (3.375/2) = 0.0095 in the hole
Could always offset grind to 3.5" use a Chevy 6.8 and the same piston to end up 0.007 in the hole and some small CID gains.
9.98 - 6.8 - 1.423 - (3.5/2) = 0.007 in the hole
Both ways would be extra work though, but are shelf piston options.
Re: 400 stock stroke pistons [Re: killermopar] #2222804
12/29/16 03:06 PM
12/29/16 03:06 PM
So. Burlington, Vt.
So. Burlington, Vt.
Using the stock stroke with the 6.86 rod and shelf piston isn't any more work than doing it with stock length rods and stock c/h pistons.
Re: 400 stock stroke pistons [Re: fast68plymouth] #2222813
12/29/16 03:13 PM
12/29/16 03:13 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
True, the bore sizes on that shelf piston could run into issues though if the block needs more then +033 but other companies could make them bigger, I just haven't looked
Re: 400 stock stroke pistons [Re: killermopar] #2222819
12/29/16 03:25 PM
12/29/16 03:25 PM
Spencer NY
Spencer NY
The block is a virgin, and has no ridge at all and no pitting. But that doesn't account for taper, or out of roundness.
Re: 400 stock stroke pistons [Re: killermopar] #2222941
12/29/16 07:45 PM
12/29/16 07:45 PM
Spencer NY
Spencer NY
Thank you guys for your info. It's a lot to think about, and I was just going to build a 500 at first, but still haven't totally made up my mind.
Re: 400 stock stroke pistons [Re: killermopar] #2222984
12/29/16 09:45 PM
12/29/16 09:45 PM
So. Burlington, Vt.
So. Burlington, Vt.
Basically, it's either 50, 70, or 110 more cubes for the difference in cost between a new crank and what it'll cost you to have one cleaned, magged, ground.
Personally, I think the low deck 511 is a great little package.
