Carter carb identification needed... #2222453
12/28/16 10:03 PM
12/28/16 10:03 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Any carb gurus out there? I've accumulated some carbs over the years and was curious of their age and application. I pulled 3 out of my stash and Wrote down the numbers....
First is a Carter AVS FO 4966S
Second is a Carter AFB J2 9635S
Third is a Carter Thermoquad 9801S 150 0
Any info would be appreciated.
Tom
Re: Carter carb identification needed... [Re: Finoke] #2222482
12/28/16 10:49 PM
12/28/16 10:49 PM
MO
cdp Offline
cdp  Offline
MO
4966...71-440-low performance. very common carb.
9635S GM-Universal Linkage electric choke
Performance Features:
* 625 CFM
* Emission & EGR Hookup Provisions
* Dual Floats
* No Power Valve, No Sticky Gaskets, No Problems
* Spring Loaded Needle & Seat Assemblies
* Square Mounting Flange - Bolt On Improvement
* Use Adaptor #C4010 for speadbore manifold
Re: Carter carb identification needed... [Re: cdp] #2222769
12/29/16 02:21 PM
12/29/16 02:21 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
* 625 CFM
* Dual Floats
Excellent, thank you! beer
Re: Carter carb identification needed... [Re: Finoke] #2222860
12/29/16 04:44 PM
12/29/16 04:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Carter TQ Model 9810
Aftermarket 9000 series
Application , GM, EGR
Primary Jet 4095
Secondary Jet 5137
Rod 2110
Bore 1 3/8"
Re: Carter carb identification needed... [Re: John_Kunkel] #2222864
12/29/16 04:52 PM
12/29/16 04:52 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Primary Jet 4095
Secondary Jet 5137
Rod 2110
Bore 1 3/8"
Awesome, thanks John! beer
