Re: alloy block piston clearence.
[Re: rebel]
#2221510
12/27/16 04:00 AM
12/27/16 04:00 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
I would contact the block and rod makers and ask them ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I seem to remember that .035 on steel rods with a aluminum KB dry sleeve street hemi block at room temperatures with aluminum heads was what I was told by Carillo and Ken Black back in the late 1990s, maybe not
[Re: rebel]
#2221541
12/27/16 09:48 AM
12/27/16 09:48 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Most Felpro gaskets are .039" thick, if I remember correctly. That would put you at .029" piston to head clearance, a bit too tight for me. You might want to consider thicker alternatives for gaskets. I don't know if shaving the pistons down would be practical. I'm not sure if it would be enough to require a rebalance.
[image][/image]
[Re: KOS]
#2221655
12/27/16 03:37 PM
12/27/16 03:37 PM
Cab_Burge
felpro makes a .051 thick gasket or mr.gasket does......alum block will grow .010-.015. They get taller when warm ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) I don't know the part number for the Fel Pro .052 thick marine head gaskets but I do remember Dominic using them and the combustion chamber I.D was for a large bore motor, like 4.540+ ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: rebel]
#2222179
12/28/16 01:58 PM
12/28/16 01:58 PM
Posts: 2,013 Apollo, PA.
B1MAXX
Apollo, PA.
hey guys i already know Cometic will make any size gasket i like, i'm really just wanting to know how close of a clearence you can start off with with a alloy block. Summit sell Cometics in .045 & .051 off the shelf, i'm leaning toward .045 as that will give me .035+- static & then the block will grow from there.i'm really just looking for reassurance this is the path i should take. i'm down under & our race season has started, i had a small failure on our first meeting, i want to be back for the rest of the meetings this summer. i don't want to skim pistons or anything as its all freshly balanced, i just want the quick cure
.035 is good for a steel rod.
