Re: Exhaust choices
[Re: Shatar4]
#2221046
12/26/16 12:51 PM
12/26/16 12:51 PM
RapidRobert
No exp with Borla but what about some vacuum or electric cutouts right at the collector along with restricted (quiet) muffs (maybe 2 per side? Quiet most of the time (keeps cops/neighbors happy & you happy) & full power (& noise) only for the 10 seconds stretch that it is needed. Helps with the shock/stealth factor! Otherwise with a good (more restricted) muff choice I would suggest an X pipe system with in addition glasspacks alongside the leaf spring (Cherrybombs I used have outward punched louvers & no neckdown where the end nipples are welded to the case=least restriction) and lookup Helmholtz (sp) resonators in exhaust science something about welding in some some 1 foot or so sideways horizontle pipes in the bend over the axles & capped on the ends, something about it cancelling sound waves as tehy bounce back & reportedly it works. Loud pipes is high school stuff & I prefer to overwhelm em when I drop the hammer! Holler how it turns out as I wanna build a 543 with a 'source 2k RB stroker kit when I hit the lottery. I have a good block so I'm on my way. EDIT good info on youtube if you have the time
Re: Exhaust choices
[Re: DaytonaTurbo]
#2222115
12/28/16 12:01 PM
12/28/16 12:01 PM
Posts: 1,652 PA
70Duster
PA
I prefer the dynomax ultra flows, not a fan of magnaflow or borla.
Another vote for Dynomax UltraFlows.
Re: Exhaust choices
[Re: Shatar4]
#2222837
12/29/16 03:55 PM
12/29/16 03:55 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
I have a Magnaflow 3" exhaust system on my 71 Challenger. I have a 505 stroker in it and I must say these mufflers are so loud that it doesn't seem they are even on it. I was thinking of going with the Borla mufflers but wanted to see if anyone has these on their car and if they like them. Thanks one picture is sideways the other upside down It's a combination of the pipe size and the straight thru muffler. Do you have an H or an X pipe ? Get a bullet type resonator and put them next to the tank and see if that tones it down some. Classic chambered sold/made by the board member in Michigan ...
Mainstream Media is the new Pravda
Re: Exhaust choices
[Re: 70Duster]
#2222841
12/29/16 03:57 PM
12/29/16 03:57 PM
Posts: 1,015 LEE, MASS
TOMRR
LEE, MASS
Re: Exhaust choices
[Re: Shatar4]
#2222912
12/29/16 06:58 PM
12/29/16 06:58 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Look at the Jones brand of mufflers on Summit's website.
Re: Exhaust choices
[Re: Shatar4]
#2223198
12/30/16 04:22 AM
12/30/16 04:22 AM
Posts: 8,460 Highland, MI.
Sunroofcuda
Highland, MI.
OK - you have room for some 3" core & 4" OD body resonators back next to the gas tank. 18" long bodies. Give me a call & I'll make you a set. -Eric www.classicchambered.com
Re: Exhaust choices
[Re: Sunroofcuda]
#2297435
05/01/17 10:13 PM
05/01/17 10:13 PM
Posts: 1,038 Howell, Mi
Shatar4
Howell, Mi
OK - you have room for some 3" core & 4" OD body resonators back next to the gas tank. 18" long bodies. Give me a call & I'll make you a set. -Eric www.classicchambered.com Do I put these on in place of or with the mufflers?
Re: Exhaust choices
[Re: Shatar4]
#2297437
05/01/17 10:19 PM
05/01/17 10:19 PM
RapidRobert
you install these alongside the springs in addition to your regular muffs up front. I would use some cheap parts house "cherry bombs". the louvers are punched outward and the end nipples do not neck down where they are welded to the main case (both for no restriction). if you can get these in 3" I would. I have a pair on my 85 Ramcharger (by themselves) & they do muffle adequately & they will help you for cheap. (maybe even (2) per side if you have the room). EDIT I just called O'reillys & they have em in 16 & 28" lengths (3").
Re: Exhaust choices
[Re: Shatar4]
#2297608
05/02/17 09:53 AM
05/02/17 09:53 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
Guys, if the OP thinks his current Magnaflows are too loud, he's not gonna be happy w/ Dynomax Ultraflows either. They're so similar it's not worth making the swap.
If you want it quieter, then go w/ something like a Dynomax Super Turbo. Much quieter than the straight through style mufflers, but still sounds real good. Just be prepared for some loss of power.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
