Predator heads #2220689
12/25/16 03:42 PM
12/25/16 03:42 PM
Newfoundland,Canada
avenger572 Offline OP
Newfoundland,Canada
I was hoping somebody came help me with some measurements.l need the measurement from the block deck serface to the top of the valve cover and from the valley tray surface to the intake carb flange . The intake would be a single 4 . Im currently running indy 572 heads and a single plane indy intake ,need to know how much changes i would have to the car to use the predator heads and intake .
Paul
Re: Predator heads [Re: avenger572] #2220777
12/25/16 06:30 PM
12/25/16 06:30 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
the block deck surface to the top of the valve cover. 9.25
valley tray surface to the intake carb flange. 8 5/8
Joe
Without Data, you’re just another guy with an opinion.
Re: Predator heads [Re: avenger572] #2220891
12/25/16 11:25 PM
12/25/16 11:25 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I believe the Predator heads only fit a Hemi block if I am not mistaken...
Re: Predator heads [Re: Dragula] #2220901
12/25/16 11:58 PM
12/25/16 11:58 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
They are available with both bolt patterns... wedge is an additional upgrade.
