Re: paint job on a budget!?
[Re: MoparforLife]
#22190
03/16/06 01:09 PM
03/16/06 01:09 PM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
The more I read this strng the more I am coninced that although the results for some of you are good. It is starting to look to me that if your time is worth anything at all you would be ahead of the game by spraying a little more expensive paint and being done with it.
that would be true if you have the space, and equipment not to mention the skill!!! having done both i would agree with you, but once you have the technique down pat it's actually alot eaiser then spraying. also spraying requires alot more skill, there's primers, primer sealers, paint, reducers, re-coat windows, ect...alot more can go wrong when you spray, for the first-timer (ie-amateur) this method is eaiser, and alot eaiser to fix if you mess up, not to mention that if it does'nt workout for you your only out a few $, instead of $300 of material, and a huge mess on your hands (been there, done that!!!) the first time i sprayed paint it really messed up, i probally created 4 times the work it would have took if i knew what i was doing. i would consider myself a seasoned semi-pro do-it-yourself painter in the spraying department. i can spray a car with basically professional results in my garage. i was going to spray the charger but it barley fit in my garage, not enough room to confortably work around it to spray. since i was a seasoned roller painter i just rollered it!!!! i'm very happy with the results, no complaints. I guess it's easy to say "just spray it" if you know how, but to a newbie spraying is scarry, it's also a valid fear as ALOT can go wrong. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 69chargeryeehaa]
#22191
03/16/06 01:27 PM
03/16/06 01:27 PM
On top of that, the results many are sharing are far from satisfactory - mainly no real cure/soft paint. If the paint available in the US is not the same formula and takes forever to cure (if at all adequately), it doesn't seem worth the effort.
#22192
03/16/06 01:46 PM
03/16/06 01:46 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
P.S. - EXIT1965- quit painting test areas and paint that damm car allready!!!!! next pic i want to see is a done car!!!! lol
Yes, I want to see that too, believe me! But I am still not convinced of which rustoleum product would be best to use, so I'm experimenting more with the pro stuff.
I am doing these test areas in my spare time, while bondo is drying, etc. I welded up all but 7 trim holes last night, I am making progress fast so who knows, I could start painting my car within a month as much time as I've been spending on it.
And I got a PM from a guy who tried Acetone, and it dried too fast for him, got all sticky and turned into a big mess- so Im not seeing a good reason to switch from mineral spirits. ![](/ubbthreads/images/graemlins/burnout.gif)
[Re: Exit1965]
#22193
03/16/06 02:01 PM
03/16/06 02:01 PM
Rolling paint on is much easier than spraying. There is no mess, I just have some blue tape along the window edges and around the door handles, nothing on the floor, no big plastic drapes, etc. No overspray to cover all the other stuff in my garage either and NO SMELL. The technique is easy, just roll it on and it evens itself out. The problem I have is, I'll have a great looking car with about 10hrs total work into it...BUT YOU CAN'T TOUCH IT OR THE PAINT WILL SCRATCH OFF ![](/ubbthreads/images/graemlins/maad.gif) Somehow I think rustoleum just doesn't bond well to urethane primer. Maybe if I can figure a way to spray some clear over the top?
#22194
03/16/06 02:15 PM
03/16/06 02:15 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
The car was primered with what I beleive is a urethane primer (typical grey, nice and smooth, not rattle can).
Prioer to painting, I did some bondo work on a few areas I wanted to smooth out and I tossed a little rattlecan primer on top of that. Once everything was dry, I first sanded it all with 150 and then followed it with 320 grit, I washed the entire car down with simple green and used a brush to scrub everything, then I let it dry and wiped it all down with a rag and mineral spirits. I waited a few hours to make sure everything was dry and I started rolling on the paint...
I think surface prep is part of your problem. most polyester fillers (bondo) absorb water. using a water based product like simple green could trap moisture in there, and using a slow-flash solvent like mineral spirits probably doesn't help, either. for the rustoleum, I'd probably go rougher on your sanding of the primer, maybe 180 grit. then instead of using a water based degreaser or mineral spirits, I'd wipe it down with lacquer thinner or brake cleaner and then paint. also, the two guys having the problem with regular rustoleum are in CA. wouldn't be suprised if your formulation is different. I'd probably stick with the professional or industrial stuff if I were you.
#22195
03/16/06 02:57 PM
03/16/06 02:57 PM
69chargeryeehaa
toronto canada
the problem you have is with the initial bond with the primer. i hope you did a test area and not the whole car ???? spraying clear on the paint will not solve the problem. there must be a issue with the surface prep. i've painted over urethane primer with no issues. ![](/ubbthreads/images/graemlins/beer.gif)
#22196
03/16/06 03:12 PM
03/16/06 03:12 PM
I already did paint the whole car. I did a small test area and it seemed to work fine, but I didn't try and scrape it that hard :lol:
#22197
03/16/06 03:25 PM
03/16/06 03:25 PM
hi all, new here,but have been reading this post,,,and even trying the painting myself,,i'll try and post a pic. i'll talk more later about what i used,,,just wanted to see if the pic would upload.
#22198
03/16/06 03:32 PM
03/16/06 03:32 PM
Been following this thread for awhile. I'm a little confused on one point though. Should one use a primer/sealer or not? I'm in the process of stripping my car to bare metal, and am wondering if I will be just painting the Rustoleum over the metal directly, or primer first? Also, has anyone done the paint over something like Rust Bullet or Por 15?
#22199
03/16/06 03:57 PM
03/16/06 03:57 PM
Hey Guys Right now I am painting my hole car. I am using Rustoleum Professional thinned with mineral spirits. And so far so good. The adhesion of the paint is good. I almost can't scratch the paint and I did my second coat this morning. I am painting over Base Coat and Clear Coat without even sanding except for making the surface smooth (the clear coat of my car it is peeling off). I am just using a scratch pad with soapy water and then, when it is dry, cleaning with rag and acetone. The Rustoleum professional dries in 2 or 3 hours, at least here in Florida with 80 Fahrenheit. Do not use acetone, doesn't work. ![](/ubbthreads/images/graemlins/tsk.gif) Acetone dries to quickly. There is no time for the paint to "self level", and the coat turns out too thick Good luck to all of you! I will keep you updated
#22200
03/16/06 05:51 PM
03/16/06 05:51 PM
69chargeryeehaa
toronto canada
if the whole car was bare metal, i'd use the rustoleum/tremclad primer, if it's just spots i would not bother with the primer. i've never painted over completely bare metal. but i'd immagine nothing would happen if you just used the paint right over the metal. i've painted over por 15 on some suspension parts no issues, rust bullet i'd think should be no issue. ![](/ubbthreads/images/graemlins/beer.gif)
#22201
03/16/06 05:54 PM
03/16/06 05:54 PM
69chargeryeehaa
toronto canada
Hey Guys Right now I am painting my hole car. I am using Rustoleum Professional thinned with mineral spirits. And so far so good. The adhesion of the paint is good. I almost can't scratch the paint and I did my second coat this morning. I am painting over Base Coat and Clear Coat without even sanding except for making the surface smooth (the clear coat of my car it is peeling off). I am just using a scratch pad with soapy water and then, when it is dry, cleaning with rag and acetone. The Rustoleum professional dries in 2 or 3 hours, at least here in Florida with 80 Fahrenheit. Do not use acetone, doesn't work. Acetone dries to quickly. There is no time for the paint to "self level", and the coat turns out too thick Good luck to all of you! I will keep you updated
sounds good, resist the urge to do the scratch test!!! wait about 4 months, i'd bet it'll be fine. the only advise i can say is that i would still sand the car with 400 to remove any wax, ect, and give the new paint something to "grab" onto. post some pics!!! ![](/ubbthreads/images/graemlins/beer.gif)
#22202
03/16/06 05:56 PM
03/16/06 05:56 PM
69chargeryeehaa
toronto canada
looks good, it'll look amazing after wetsanding/polishing. ![](/ubbthreads/images/graemlins/drool5.gif)
[Re: Jerry]
#22204
03/16/06 06:40 PM
03/16/06 06:40 PM
69chargeryeehaa
toronto canada
are these gloss paints being used or just the standard rustoleum ones? i know that on the rustoleum site the specificy gloss black and gloss of other colors but not all of them. does a gloss paint need to used for it to be shiny? i'm thinking of trying this on my satellite when the weather gets better up here in michigan.
yes, they are gloss paints, it says on the can what the finish is. ![](/ubbthreads/images/graemlins/beer.gif)
#22205
03/17/06 01:53 AM
03/17/06 01:53 AM
Did you try putting a heat lamp or hitting a spot with a heat gun to see what happens if you accellerate the cure with the heat? I haven't heard of anyone trying it yet, and I found using heat on repairs I had to do was the only way I could get them on the road fast enough.
#22206
03/17/06 08:21 AM
03/17/06 08:21 AM
I've been reading this lately and I just wanted to test this out on a spare door I can get from a junkyard. The only problem I am having is wetsanding, now I understand the grits and spraying down the paper, sanding, then cleaning with the shammy and clean water. But how deep do you want to go when you actually do your first 2 coats then resand with a higher grit. Also I've seen some forums about wetsanding and they said to use soap with a bucket of water, but dont specify on what kind or if it helps / worsens, the situation. 69Charger or anybody else wish to enlighten me? Thanks
#22207
03/17/06 09:36 AM
03/17/06 09:36 AM
Exit1965
Rancho Cordova, CA
If you have no runs, just wetsand it until it's smooth (you can see this by wiping the area with water or mineral spirits), which normally doesn't take too much paint off. But it removes the gloss, and there's a fresh cut potato smell (!). I had some runs in my most recent test area, and I'm having to wetsand more because I do the whole area, not just where the run is. In that case, sand until the run disappears.
Also when you're wetsanding, when you spray the surface it will be tiny water drops. After sanding, if you spray water, the water will be more evenly dispersed. It's a good way to tell if you've missed an area with your sandpaper. Also I would use a foam sanding block with the 600/800/1500 grit wrapped around it. I have been using that, and it doesn't load up like it might with a hard block.
[Re: GTSDave]
#22209
03/17/06 12:44 PM
03/17/06 12:44 PM
hi all, i tried to post a little about my experience earlier,but by the time i got done writing the (novel)and submit it,it wouldnt submit.i do want to thank "69charger"for bringing this method of painting to light. ![](/ubbthreads/images/graemlins/bow.gif) .in he beginning he said it would take patience and practice,and i cant agree more,but after about 4 or 5 weeks of playing around,my project is actually starting to show some promise.thanks again "69charger".
