Page 2 of 7 1 2 3 4 5 6 7
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2220368
12/24/16 07:42 PM
12/24/16 07:42 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
My car with the same exhaust system other than having long tubes (and Ultra-Flos which should be worse than super turbos) had more drone noticeable with the TTI turn-downs on it. I eventually cut them off and went with some tips that stick about an inch past the bumper and its a lot more bearable. I think those TTI turndowns cause some "drumming" under the car.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Exhaust Interference and Drone Problems [Re: goldduster318] #2220401
12/24/16 08:48 PM
12/24/16 08:48 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Could you temporarily try taking the turn down tips off just to see if they are causing it?
I once had a car with full length exhaust exiting into exhaust tips that ran parallel with the ground exiting under the rear valance and never had a drone issue at any rpm. It had Hooker Aero Chambers and 2.5" pipe start to finish.
Re: Exhaust Interference and Drone Problems [Re: YO7_A66] #2220408
12/24/16 08:58 PM
12/24/16 08:58 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Originally Posted By YO7_A66
Eric at Classic Chambered Exhaust made me a set of these 2.5" resonators to fit beside the gas tank on my 70 Challenger. He made them so that they would bolt onto my new 2.5" R/T exhaust tips. All I had to do is cut off the rear TTi exhaust pipe and clamp them on.
Very cool. What was the change in loudness and drone?
On A-bodies with full exhaust the leaf spring and gas tank barely fit 2 1/2" exhaust. So can go any wider than that. Can go up and downward for a box or oval type deal with the same width as the inlet and outlet diameters. Never seen a 2 1/2" resonator like that.
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2220420
12/24/16 09:32 PM
12/24/16 09:32 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Are those really TTI shorty Headers? The first tube seem to drop down instead of angling back at around 45 degrees.
A new iron curtain drawn across the 49th parallel
Re: Exhaust Interference and Drone Problems [Re: 67autocross] #2220436
12/24/16 10:17 PM
12/24/16 10:17 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
I ran a full TTI system in a 68 Barracuda the super turbos drone like crazy. I now have Ultra flows much better also tail pipes are a must.
Re: Exhaust Interference and Drone Problems [Re: Neil] #2220734
12/25/16 04:58 PM
12/25/16 04:58 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
I will try that soon. Tomorrow I should have some time to play with the car and it shouldn't be raining. I'm going to start by attempting to dent the header as that needs to be done regardless. Afterwards I'll take a look at the tips. IIRC, they should only be held on by exhaust clamps, if they're welded on, I may just go with some circular resonator past the muffler.
Re: Exhaust Interference and Drone Problems [Re: autoxcuda] #2220737
12/25/16 04:59 PM
12/25/16 04:59 PM
SoCal
SoCal
I was thinking something like this may work. They don't look that much larger in diameter, but I'll have to take a better look:
https://www.summitracing.com/parts/vpe-1792/overview/
https://www.summitracing.com/parts/sle-310013919/overview/
Re: Exhaust Interference and Drone Problems [Re: 67autocross] #2220746
12/25/16 05:22 PM
12/25/16 05:22 PM
SoCal
SoCal
They're TTi's...
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2220749
12/25/16 05:28 PM
12/25/16 05:28 PM
SoCal
SoCal
So, I just took a look at the headers, and I don't know how I'm going to be able to dent these while they're still in the car. I have some flat ended punches and I can barely fit them around there. Even with a rag on the other side, I'm worried about puncturing a tube or something as I gave them some slight hits and knicked the surface of the tubing.
As for the exhaust, the tips seem to go from the mufflers to the back of the car. So any modification will require some welding... Speaking of which, I just got a cheap flux core MIG welder for Christmas. However, I won't tackle that as my first project.
Looking at the underside, I have some room between the leaf spring and the gas tank. My exhaust is actually a lot closer to my leaf springs than it is to my tank. But if I go to the resonator route, there's plenty of space past the gas tank to mount them.
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2220938
12/26/16 01:30 AM
12/26/16 01:30 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Can you undo the motor mount and jack the engine a little to get some room to make the dent? Otherwise mark it and unbolt it. You could possibly move it enough to dent it?
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2220951
12/26/16 02:34 AM
12/26/16 02:34 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
They're TTi's...
Yea they are, most TTI shorties I have looked at had lots of space around the box. Even the stock power box clears no problem. Did you use old rubber biscuit engine mounts that may have flattened out over time?
Re: Exhaust Interference and Drone Problems [Re: Dave Hall] #2220960
12/26/16 03:13 AM
12/26/16 03:13 AM
SoCal
SoCal
I'll fiddle with it tomorrow. I have a cherry picker and some lifting chains I can try for the first time.
Re: Exhaust Interference and Drone Problems [Re: 67autocross] #2220961
12/26/16 03:15 AM
12/26/16 03:15 AM
SoCal
SoCal
They're TTi's...
I'm quite suprised as well as I know of a couple of people who have both the Borgeson box and TTi headers. But with how wishy washy factory tolerances and 40+ years of moving around anything is possible.
That's quite possible as I reused the ones that the previous owner gave me.
Re: Exhaust Interference and Drone Problems [Re: 360view] #2221343
12/26/16 09:50 PM
12/26/16 09:50 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Originally Posted By 360view
The length of your tailpipe from muffler back matters a lot to the rpm where Drone is most severe. Just as a Church Organ makes different musical notes when different length pipes get air blown through them, so will your exhaust make annoying music.
Very roughly, if drone was severe at 2000 rpm, and much less at 1500 rpm,
then your tailpipe length needs to increase
2000 divided by 1500
4/3 rds
Other things come into play here, such as the temperature of the exhaust gas, which will be higher the more the trottle is opened.
You could experiment to find the added length that snuffs out drone.
Buy two ninety degree fittings, and two lengths of either solid or flexible corrigated pipe,
and add maximum length for side outlet style exhaust,
then cut off about two inches at a time untill the exhaust note suits you.
Drive up steep hills to demonstrate how a more open throttle changes exhaust temperature and therefore drone.
The quietest set up for low drone in the 1200 to 2200 rpm range is usually large "Helmhertz Trap" mufflers mounted cross ways near the rear bumper fed by as long as possible tailpipes. T-Traps of closed stub pipes the right length can also kill drone at a particular rpm.
iagree
Really well stated. Furthermore, the tub of your unibody car is one big musical instrument as well. When the mufflers resonate, all that harmonic vibration will make the car itself drone. In fact, much of what you're hearing is the car! If you haven't gone the dynamat route this will help a bit but not completely. The last car that I installed dumps on was longer ago than I'd like to say. I found a great solution for the drone. I purchased a pair of Thrush resonators and installed them after my mufflers and added about a foot of pipe beyond them so the dumps dropped right in front of the rear axle and it completely solve my problem. Before I installed the resonators, the drone was unbearable like yours at a certain RPM. Second gear was a real beotch. Just remember that the harmonics of every exhaust system are different, so what worked for me may not work for you.
If you want to see how harmonics work go inside a walking tunnel of decent length with smooth surfaces. Stand in the middle. Then start singing a low note and start raising the pitch. At some point your voice will begin to make the tunnel start ringing really loud!
I’m listening.
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2221354
12/26/16 10:19 PM
12/26/16 10:19 PM
SoCal
SoCal
Well, I'm having trouble with denting the headers. I tend to be a wuss when it comes to hitting things as sometimes I don't know my own strength and may break something if I try to hard. How hard can I hit this thing? Right now I'm using a punch with a flat end on it (microfiber wrapped around the edge) and a hammer. This is all inside the car as I just realized the headers don't have hex-head bolts but the 12-point or sided bolt (I don't remember what they're called) and I don't have those sockets on hand (another thing for the wish list). My last resort is to undo the motor mounts and move the engine.
Re: Exhaust Interference and Drone Problems [Re: Big Bad Bee] #2221356
12/26/16 10:24 PM
12/26/16 10:24 PM
SoCal
SoCal
4/3 rds
iagree
As of now, I have no sound deadening in the car. I wanted to lay some in the back for the electric fuel pump as that can get very noisy. But since the car is so stiff, the vibration is just circulating everywhere as it's trying to find something to give. 6th gear is unbeable between 65-80 mph (optimal CA cruising speeds). The magnitude of the drone is less at lower speeds.
The problem is that the TTi system uses offset mufflers so I'm going to need my resonators behind the rear axle. There's plenty of room after the gas tank, but how much room after the resonators do you generally need before dumping the exhaust? Can you do it at the resonator outlet? A couple inches? I don't think I have enough room for a 12-18" resonator and another 12" of tubing.
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2221363
12/26/16 10:35 PM
12/26/16 10:35 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
If the header tube is just barely touching the steering box and there are no sharp spots to wear thru the header tube I would just leave it alone.
My dad has an early nova and the steering link touches the headers at full lock. While it has left some small witness marks on the headers it's not enough to justify wrecking the ceramic coating by beating dents in them for that last 1/16" - 1/8" of space.
Do you have a spare tire and rubber trunk mat? If not that may help as well.
Re: Exhaust Interference and Drone Problems [Re: Neil] #2221367
12/26/16 10:38 PM
12/26/16 10:38 PM
SoCal
SoCal
I might at this point, but we'll see. The side of the header contacts the round body of the steering box.
I need to measure/find a spare wheel for this car as I've got the big brakes up front. But it's in the works. No rubber mat either.
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2221459
12/27/16 01:23 AM
12/27/16 01:23 AM
How about using a large flat bladed screwdriver or stock type lug wrench flat tapered end to push in between the header tube and steering box and used that to push it in a little work scope
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2221468
12/27/16 01:32 AM
12/27/16 01:32 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
They're TTi's...
I would fix the engine mount before you start bashing the header, if you have looked at other cars with the same headers and box you already know that you should have lots of clearance in that area. I guess that whoever put the engine in just bolted it in wherever it landed in the engine bay....
