Re: Dana 60 housing ends
[Re: Acme Rocket]
#221813
02/12/09 12:33 AM
02/12/09 12:33 AM
Triple Threat
Renton Washington
I am in the same boat in needing to make this decision. We shall see what others have to say ....
[Re: Triple Threat]
#221814
02/12/09 12:53 AM
02/12/09 12:53 AM
Posts: 576 Somewhere Over the Hill
Mr. Dodge
I used the Ford ends, Reason being I can get disk brake parts a whole lot cheaper that having the Mopar ends......
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison)
69 Hemi Coronet R/T
70 456 Dart Swinger
[Re: hot67cuda]
#221816
02/12/09 01:28 AM
02/12/09 01:28 AM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
Where do you guys get these ends from?
josh
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
[Re: ToddP]
#221828
02/12/09 09:50 AM
02/12/09 09:50 AM
Posts: 470 Big Chicago
amixon
Big Chicago
this is rear end that you are building from scratch right? The reason I like the LBF ends is the piece of mind that that Timken Taper bearing gives me. I have had a Green style bearing fail on a car ( a street car but still) and the only thing that kept the axle in was the fender skirts (68 VIP). The fact that a part was used by Ford,Gm, Toyota or Renault (ok maybe not anything from France ) dosen't make it automatically bad to me, but then again I am not a Mopar purist-more like a mut that likes things that work well and happens to only own Mothers products-for now. Just had to add and additional
[Re: DoctorDiff]
#221831
02/13/09 12:21 AM
02/13/09 12:21 AM
Posts: 989 Rather be in Fallon, Nevada
RussW
super gas
super gas
BTW, Timken tapered wheel bearings failed on my dad's 1/2 ton Ford pickup. There was nothing that kept the axle in the wheel well.
8.8 ?
Chassisworks has the Torino ends and I used the 11 brake kit from Moser .
