LA 340/360 stroker racers questions on stroke length #2217566
12/20/16 05:27 AM
12/20/16 05:27 AM
Cab_Burge Offline OP
I have heard that you can use a 4.125 stroke crank with 2.000 rod journal sizes and SB Chevy forged steel I beam or H beam rods without having interference with the cam or block on both the 340 and 360 stock LA blocks, is this true or baloney sauce confused help
I'm thinking of doing this in a 360 block and want to hear from other Mopar SB LA engine racers on here before I end up finding out the hard way that you shouldn't or can't do that with a stock production OEM passenger car block help
Thanks in advance for your help on this thumbs
Re: LA 340/360 stroker racers questions on stroke length [Re: Cab_Burge] #2217642
12/20/16 11:44 AM
12/20/16 11:44 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
True Story, BPE sells a 4.125 crank.
68 Barracuda Formula S 340
Re: LA 340/360 stroker racers questions on stroke length [Re: Cab_Burge] #2217644
12/20/16 11:45 AM
12/20/16 11:45 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Cab,
This is a BPE 4.25" stroke in a stock .060" '71 360 block....uses 6.200" rods with 2.00" (327 chevy) sized journals.
WIZE
In Car:
Re: LA 340/360 stroker racers questions on stroke length [Re: Cab_Burge] #2217858
12/20/16 04:41 PM
12/20/16 04:41 PM
BPE Offline
BPE  Offline
Yep, it works. I will post up some pics tonight if I have time.
Rod
Re: LA 340/360 stroker racers questions on stroke length [Re: BPE] #2217927
12/20/16 06:56 PM
12/20/16 06:56 PM
Rod
up Thanks for that bow
Re: LA 340/360 stroker racers questions on stroke length [Re: Cab_Burge] #2217951
12/20/16 07:41 PM
12/20/16 07:41 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Here's pretty much all you would ever want to know right here in the tech Archives:
https://board.moparts.org/ubbthreads/ubbt...html#Post912622
WIZE
In Car:
Re: LA 340/360 stroker racers questions on stroke length [Re: Cab_Burge] #2217956
12/20/16 07:58 PM
12/20/16 07:58 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I did one of Rods kits last summer 4.125 chevy rod 360 40 over work out great very nice stuff and his prices or more the fair thanks rod
Re: LA 340/360 stroker racers questions on stroke length [Re: scottb] #2218031
12/20/16 10:25 PM
12/20/16 10:25 PM
BPE Offline
BPE  Offline
Stock 360 Block 4.250" crank with a 4.03" bore.
Rod
Re: LA 340/360 stroker racers questions on stroke length [Re: BPE] #2218032
12/20/16 10:26 PM
12/20/16 10:26 PM
BPE Offline
BPE  Offline
Stock 360 block with 4.250" clearance to pan rail.
Rod
Re: LA 340/360 stroker racers questions on stroke length [Re: Cab_Burge] #2218057
12/20/16 10:49 PM
12/20/16 10:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I used one of Rods 4.125" cranks with 2.00" journals and 6.200" rods in my R1 block. The only issue was the crank key way is off 2.5°, no big deal just have to remember when timing it.
Re: LA 340/360 stroker racers questions on stroke length [Re: justinp61] #2218085
12/20/16 11:25 PM
12/20/16 11:25 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I'm curious about longevity with that much stroke in a stock block? At what performance level? High compression ect.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: LA 340/360 stroker racers questions on stroke length [Re: FurryStump] #2222470
12/28/16 10:26 PM
12/28/16 10:26 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
What is the clearance on the oil pump
Re: LA 340/360 stroker racers questions on stroke length [Re: littleVAL] #2222720
12/29/16 12:59 PM
12/29/16 12:59 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
With a 3.91 crank and alum 6.4 rods I had pickup tube problems. Had to eventually shim the oil pump to provide adequate clearance. Worked out well.
Re: LA 340/360 stroker racers questions on stroke length [Re: Blucuda413] #2222778
12/29/16 02:30 PM
12/29/16 02:30 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
What was the rod journal size?
Re: LA 340/360 stroker racers questions on stroke length [Re: littleVAL] #2222779
12/29/16 02:32 PM
12/29/16 02:32 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
With my above mentioned crank and rod I had about .125" with the Milodon pick up.
Re: LA 340/360 stroker racers questions on stroke length [Re: justinp61] #2222815
12/29/16 03:17 PM
12/29/16 03:17 PM
BPE Offline
BPE  Offline
Stock 360 block, with a 4.250" crank and the rods I supply with my kits. Milodon pick up also used here as well.
Rod
Re: LA 340/360 stroker racers questions on stroke length [Re: Cab_Burge] #2223196
12/30/16 04:15 AM
12/30/16 04:15 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Justin I have MGP rods with 2" journals. Also on my pickup arm even after grinding and hammering it I still had to shim the oil pump. I believe the oil pump is sometime the problem.. After recently looking at several pumps their sizes are not standard even with the same part numbers. I'm sure it is because of different batches or different suppliers. I'm using steel rods in my next build so may not have the same problem.
Re: LA 340/360 stroker racers questions on stroke length [Re: Cab_Burge] #2223197
12/30/16 04:18 AM
12/30/16 04:18 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
