Re: LA 340/360 stroker racers questions on stroke length
[Re: Cab_Burge]
#2217642
12/20/16 11:44 AM
12/20/16 11:44 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
True Story, BPE sells a 4.125 crank.
68 Barracuda Formula S 340
[Re: Cab_Burge]
#2217644
12/20/16 11:45 AM
12/20/16 11:45 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Cab,
This is a BPE 4.25" stroke in a stock .060" '71 360 block....uses 6.200" rods with 2.00" (327 chevy) sized journals.
[Re: Blucuda413]
#2222778
12/29/16 02:30 PM
12/29/16 02:30 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
With a 3.91 crank and alum 6.4 rods I had pickup tube problems. Had to eventually shim the oil pump to provide adequate clearance. Worked out well. What was the rod journal size?
[Re: littleVAL]
#2222779
12/29/16 02:32 PM
12/29/16 02:32 PM
justinp61
W. Kentucky
What is the clearance on the oil pump With my above mentioned crank and rod I had about .125" with the Milodon pick up.
