Clutchflight #221586
02/11/09 08:38 PM
02/11/09 08:38 PM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
Did these things use an external pump so the trans was hydraulicly engauged before engauging the clutch, or did the clutch drive the pump?
Re: Clutchflight [Re: TRENDZ] #221587
02/11/09 08:39 PM
02/11/09 08:39 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
PM B1Headman. Scott Koffel is pretty good at these. I'm sure there are others.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Clutchflight [Re: TRENDZ] #221588
02/11/09 08:41 PM
02/11/09 08:41 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Both ways were used.The early cars used a power steering pump and later units had a 3 finger tang to drive the front pump.
Nautilus Racing-
Re: Clutchflight [Re: sunroofgtx] #221589
02/11/09 09:55 PM
02/11/09 09:55 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
I'm doin one right now and looking for any info. Trying figure out which billet drum will work cause it's the early 62-5 t flite. Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Clutchflight [Re: mr2performance] #221590
02/12/09 12:39 AM
02/12/09 12:39 AM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Mike, you need a website! I'm sure you're too busy, but I'm also sure a ton of us would love to see some more of your work.
I'm Gumby dammit!
Re: Clutchflight [Re: Gumbydammit] #221591
02/12/09 08:21 AM
02/12/09 08:21 AM
Lebanon,IN
Lebanon,IN
It's almost finished, some hackers killed the server last time and it cost me 5k worth of site work. I figured I'd take my time this time. Mike I'll let moparts know when its up. mr2performance.com is the site domain.
Re: Clutchflight [Re: TRENDZ] #221592
02/12/09 05:30 PM
02/12/09 05:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The link below shows pics of the Clutchflite and the pump drive spider:
http://s22.photobucket.com/albums/b311/root66/727CF/
Aftermarket setups mostly used the spider, the original factory setup used a P/S pump.
