Organsol Tips #2211333
12/10/16 04:53 PM
12/10/16 04:53 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
I need to do a small touch up of organosol paint, it's a small spot, has anybody tried touch ups with a small brush?
Re: Organsol Tips [Re: 71birdJ68] #2213461
12/13/16 07:07 PM
12/13/16 07:07 PM
Chicago
PurpleBeeper Offline
Chicago
Yes, I have an it left terrible brush marks. If you can be ULTRA patient and cut the organisol in 1/2 with MEK (methyl ethyl ketone) you "might" not have brush marks....if you do it in 4-5 coats......"might". Why not spray it? Is the part installed and hard to spray?
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Organsol Tips [Re: PurpleBeeper] #2213480
12/13/16 07:42 PM
12/13/16 07:42 PM
Morristown Tn.
Morristown Tn.
Yes, hard to spray. 71 air grabber, right behind the scoop. I opened the scoop and it rubbed against the bubble, I later shimmed the hinge to fix it. The paint job is done, so I don't want to mess with that. It's just about 1 long by 1/2 inch, the thickness of the bubble, but it can be seen.
Re: Organsol Tips [Re: 71birdJ68] #2213599
12/13/16 11:13 PM
12/13/16 11:13 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
How about experimenting with a stippling technique rather than brushing the Organisol.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Organsol Tips [Re: FJR doc] #2213632
12/13/16 11:56 PM
12/13/16 11:56 PM
Morristown Tn.
Morristown Tn.
Ok, I'll look into that. Thanks
Re: Organsol Tips [Re: 71birdJ68] #2213781
12/14/16 10:13 AM
12/14/16 10:13 AM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
Don`t brush it, dab it, at least the second coat . can adjust the texture
