Re: New R blocks
[Re: scottb]
#2214993
12/16/16 11:22 AM
12/16/16 11:22 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
$8700.00 invested into a Ritter block and the man has the block and has given zero back for two years now. I wouldn't buy one, would want to take the chance with my hard earned money and his track record. Another member here has ground the name Ritter off the side of his block he has so may troubles with it.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: New R blocks
[Re: J_BODY]
#2215024
12/16/16 12:17 PM
12/16/16 12:17 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
As for me.... I'm probably nearing the end of this hobby.
Didn't you just have a birthday? Not even close yet. You might need to head east and we can hit Whiskey Row
[img] [/img]
Re: New R blocks
[Re: stevet340]
#2215038
12/16/16 12:54 PM
12/16/16 12:54 PM
1967dartgt
Hilltown Pa
The ROI, Return On Investment just isn't there for Mopar parts in general. We Have new blocks available, I've heard that Indy has pallets of them and Ritter took a huge leap and had them made but nobody wants to spend the money on them. I've seen a few Rittter blocks and they are very usable! I can't see any reason for anyone else to make them, and why would you? For 1/2 dozen or so guys who will complain about the price, work involved, wrong cam bearing, deck height, lifter angle, etc,etc,etc. This isn't 1978 when you can buy a new block for $200-300, with NO OPTIONS I might add, that needs work. I can't imagine why ANYONE would want a 59* block or a 9.5 deck height or regular cam bearings for that matter. This is 2016, soon to be 2017, not 1978. As for the Ritter blocks, Ken did his best to try to make a block that EVERYONE would be able to use for whatever application they had. Guys didn't/don't buy them because they take work??? There are a few guys on here that get it, as with most anything in life, you have to work for what you want, including making an engine run and making a block usuable. The rest think that because they have $$$ or spend X amount of $$$ that they shouldn't have to put the work in or have work done to a block to make it usable for THEIR APPLICATION. There is NO block out there that is ready to run direct from the manufacturer at ANY PRICE! From cylinder bore/finish, to deck height, they all need work! Not sure why everone is so bent on getting off the self parts for a race block??? Good pistons all cost the same as do good rods and billet camshafts and cranks, why not use this to your advantage???? A lot on here have no problem using the latest greatest CNC ported heads from this place or that guru or whatever, not realizing they are getting a copy of one port that was originally hand ported, made for one distinct combination, not for their combination or application! ... I have a new, unmachined, short deck 60mm cam bearing, unmachined lifter bank R3 block I paid $480.00, yes, $480.00 for that I'm dying to use but haven't finished tweaking my current combination. I'm sure I will have several thousand dollars into it, but it will be perfect for my combination and that is all that matters to me. If I needed a block, Ritter would be getting a call from me and my money. So I guess all these new tall blocks cfe and others are making for the Chevy and ford crowd are stupid and a waste of money? 9.0 deck maybe ok for na stuff but much easier to make them live on power adders with a taller deck.
Re: New R blocks
[Re: 1967dartgt]
#2215044
12/16/16 01:07 PM
12/16/16 01:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I was gonna look into a Ritter block but at the time a couple of guys were TRYING to build one.. with all the problems they were having I passed on it.. I already had a R3 in the car but I wanted something for my 59* heads.. I bought my R3 for cheap at the Indy swap meet.. I had to work on it but some of the stuff anyone would do to a new block.. line bore the mains and cam tunnel, bore the cyls.. plus I had to clearance the area around the main webs to clear the counter weights(I had turned down the counter weights already and it still hit) but it was no big deal.. I did alot of the same stuff on my new Mega block.. and I heat treated that block before any work was done on it EDIT I would like to buy a alum LA block
Re: New R blocks
[Re: stevet340]
#2215065
12/16/16 01:36 PM
12/16/16 01:36 PM
MR_P_BODY
I dont know of or ever heard of a 600+ SBM.. only one guy tried a 501ci.. it had issues.. I'd rater have a 440ci if I wanted a big ci.. but I prefer to have a bit smaller bores just to keep thick walls and save it for another bore job
Re: New R blocks
[Re: stevet340]
#2215105
12/16/16 02:50 PM
12/16/16 02:50 PM
Posts: 3,887 Smyrna, South Carolina
STEFF
the tall deck CFE chevy and ford blocks are for very large engines, 600+ inches. It is almost mandatory to be able to fit any kind of rod, crank and piston into an engine of that magnitude, along with a raised cam location to clear the crank throws.. Not sure how any type of power adder knows or cares what the deck height of an engines means/matters to it??? The deck thickness is pretty much the same on a 9.5 block as it is on a 9.0 block, if it wasn't, you could deck a 9.5 block down to 8.9 with no issues and still have plenty of deck thickness for boost or a blower or whatever, just depends on which block casting you have and how much you can mill it down as there have been several variations. Those are 4.5" bore space blocks.
Re: New R blocks
[Re: STEFF]
#2215123
12/16/16 03:36 PM
12/16/16 03:36 PM
dogdays
There are tall deck chevy smallblock blocks (4.400 bore spacing) with a raised cam. That's for those 4" and 4.125" cranks. Remember the Rocket Block? I believe you can buy (stock is 9.025") 9.300, 9.500 and maybe 9.600.
LS motors you can find either a 9.750 or 9.800 (stock is 9.240)
Thee are probably more but I didn't want to strain myself. . R.
Re: New R blocks
[Re: 1967dartgt]
#2215141
12/16/16 04:28 PM
12/16/16 04:28 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
I sure hope it happens I need two 9.600 48* blocks I have a brand new one on a skid I would sell but, I'm not giving it away? Rod Sold 3400 in about 4 hrs. F@$&!!!
Re: New R blocks
[Re: scottb]
#2215157
12/16/16 04:57 PM
12/16/16 04:57 PM
1967dartgt
Hilltown Pa
Why are we talking about 2 or 3 blocks running when this block has been out for over five years. I know of 18 that had large issues and some were not buildable.
Re: New R blocks
[Re: stevet340]
#2215158
12/16/16 05:02 PM
12/16/16 05:02 PM
1967dartgt
Hilltown Pa
the tall deck CFE chevy and ford blocks are for very large engines, 600+ inches. It is almost mandatory to be able to fit any kind of rod, crank and piston into an engine of that magnitude, along with a raised cam location to clear the crank throws.. Not sure how any type of power adder knows or cares what the deck height of an engines means/matters to it??? The deck thickness is pretty much the same on a 9.5 block as it is on a 9.0 block, if it wasn't, you could deck a 9.5 block down to 8.9 with no issues and still have plenty of deck thickness for boost or a blower or whatever, just depends on which block casting you have and how much you can mill it down as there have been several variations. I guess you never heard of compression height! That what a 9.0 deck build doesn't have. Don't tell me to run shorter rods as you need longer rods to clear large strokes. 1500 hp isn't uncommon and it's hard to make that with 358".
Re: New R blocks
[Re: scottb]
#2215188
12/16/16 05:50 PM
12/16/16 05:50 PM
Posts: 103 Kansas, Topeka
69 lawndart
Kansas, Topeka
I have both a aluminum Ritter and an R3 block together and running. both are 9.5" deck, the Ritter is 48* and the R3 is 59*. There are things I like better about both block. After a lot of input from severel members who told me the issues they had with there Ritter blocks, I have it running and everything is looking really good. If I had it to do all over again I would still do the Ritter block it wasn't that bad. I think he has most of the problems worked out. I also had a lot of problems with my R3 block. I think either block will make some good reliable power, granted I am a N/A guy, but if you going to go with a power adder then you defiantly need a good block.
Re: New R blocks
[Re: 1967dartgt]
#2215193
12/16/16 05:57 PM
12/16/16 05:57 PM
Posts: 5,997 Anoka County, MN
Leigh
Anoka County, MN
I consider all blocks, new or old, when prepped for race use, will need to be mocked up and subject to several standard machine operations. If the part has been cast with necessary blueprint features missing, it's a door stop. If the manufacturer clearly states the design and casting errors up front, let the buyer beware. If there have been revisions to the original, flawed design, those purchasers should get the corrected block.
Re: New R blocks
[Re: sst404b]
#2215210
12/16/16 06:31 PM
12/16/16 06:31 PM
MR_P_BODY
Does anyone know the price on a Ritter block and is he making them in a 59* also... I already sold off all my 48* stuff so I want a 59* thanks
Re: New R blocks
[Re: scottb]
#2215250
12/16/16 07:39 PM
12/16/16 07:39 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I'm one of the stupid, i guess, for running a 9.6" deck R3. With a 4" stroke and 6.2" rods, it keeps my R/S angle very reasonable while having 422 cubes. Could do it with a low deck, but why side load the crap out of the cylinders with a horrible R/S angle when you don't have too. Maybe this is why other manufactures make tall deck block versions....hmmmm.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: New R blocks
[Re: scottb]
#2215257
12/16/16 07:52 PM
12/16/16 07:52 PM
Posts: 20,334 Park Forest, IL
slantzilla
Park Forest, IL
How did Ritter get a block approved for Stock???????????
