yet another header question. #2203326
11/27/16 02:52 PM
11/27/16 02:52 PM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
Which make/model of header will allow me to use the factory exhaust manifold studs without denting the tubes for clearance. This is for a BB D-300. Thank-you
Re: yet another header question. [Re: blaze] #2203859
11/28/16 02:09 PM
11/28/16 02:09 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
I used Hooker Super Comps on my 440 Ramcharger.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: yet another header question. [Re: blaze] #2204383
11/29/16 01:03 PM
11/29/16 01:03 PM
scratchnfotraction Offline
I have hedman 79250 headers on my 88-440 truck
mine has all 12 stock studs, I did clean up holes while heads were on bench.
what I found was I had been putting the gasket on upside down. a machined groove across head would not let the gasket sit flat on the head around the ports. once I found that I have had no leaks at the header flange. lower collector is a ball/cone so no gaskets there.
I have the plug wire run/loomed behind the tubes with no issues. I do have heat socks on them for added protection. all 90* plug boots. same routing a 78 BB MH used with 2 center dump manifolds.
IIRC these are the same as the Bouchillon BB truck swap headers for 72-87 D series chassis.
D300 is a big open truck chassis with a solid front axle/leaf spring correct?
these headers tuck up nice and don't hang low in the chassis which is a plus sometimes.
Re: yet another header question. [Re: blaze] #2204394
11/29/16 01:22 PM
11/29/16 01:22 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I have hedman 79250 on my truck as well, they work and fit. I had to ceramic accel spark plug them BUT I pack my engine bay full of insulation to keep the mud out, there are some heat issues.
Blown Hemi - is yours a 4wd? I need bigger headers on mine, the only option I have found is the mad dog fenderwells. I always hear rumors of certain B body ones fitting but have never seen it.
Re: yet another header question. [Re: blaze] #2204401
11/29/16 01:30 PM
11/29/16 01:30 PM
I have seen 68-69 BB headers in a d-series chassis. have to trim the top edge of frame rail a tad to clear some of the tubes. but bolt in there.
Re: yet another header question. [Re: scratchnfotraction] #2205086
11/30/16 08:35 AM
11/30/16 08:35 AM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
my fault, I didn't mention that this is a '75 D-300. Coil spring A-arm style set-up. Thank-you for the replies
Re: yet another header question. [Re: blaze] #2205100
11/30/16 10:01 AM
11/30/16 10:01 AM
I'm sure the hedman 79250 B-RB will fit the bill for the a-arm chassis.
