Paint for 71 Charger louvered tri-color tail light bezels #2204596
11/29/16 06:10 PM
11/29/16 06:10 PM
SF Bay Area, CA
charger440sixpak Online content OP
charger440sixpak  Online Content OP
SF Bay Area, CA
Getting ready to repaint a set of 71 Charger R/T tail light bezels and started searching for the Krylon 2521 discussed here: Moparts thread
Having no luck, I contacted Krylon and the K02521 color is no longer in production and they showed no stock anywhere in the US. So what's the next best choice? Herb's dark argent #2032? Or has someone found something that's a good match?
Re: Paint for 71 Charger louvered tri-color tail light bezels [Re: charger440sixpak] #2204629
11/29/16 07:00 PM
11/29/16 07:00 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Are those textured argent or just a silver matte finish. I have some to paint.
Re: Paint for 71 Charger louvered tri-color tail light bezels [Re: NANKET] #2204663
11/29/16 07:45 PM
11/29/16 07:45 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Here's what I did.
Rear Taillights
Decided to take a look at these this past weekend, I have one NOS black and one a nice argent taillight. The plan is to re-finish them both with the tri-colour effect, black, grey (or darker argent) and argent. I am not too concerned with them looking OEM exact. I've got so many different cans of silver, argent, aluminum, grey it's getting nuts so whatever I have on my shelf that is the closest I think I will use.
Here's the black bezel.
and the argent:
Started masking:
Got it painted:
Ready to spray some argent I had kicking around for the outer part of the bezel:
Thought I'd share my mistake, I painted these two bezels two weeks apart and somewhere along the line I mixed up the finishing paint, one I used Eastwood's Spray Gray and the other is Detail Gray. I think the top is Detail Gray, when I have made the correction I'll straighten it out. :brickwall: Well at least I have two different samples.
Installed:
Re: Paint for 71 Charger louvered tri-color tail light bezels [Re: NANKET] #2204713
11/29/16 08:59 PM
11/29/16 08:59 PM
SF Bay Area, CA
SF Bay Area, CA
The Krylon 2521 was labeled as a 'texture' paint but I'm not sure how much texture was on the factory original tri-color bezels.
Re: Paint for 71 Charger louvered tri-color tail light bezels [Re: charger440sixpak] #2205667
12/01/16 01:39 AM
12/01/16 01:39 AM
Belleville Il
Dingmaster Offline
Dingmaster  Offline
Belleville Il
I used rustoleum stainless steel. Its a nice satin finish.
Re: Paint for 71 Charger louvered tri-color tail light bezels [Re: Dingmaster] #2205770
12/01/16 11:31 AM
12/01/16 11:31 AM
SF Bay Area, CA
SF Bay Area, CA
CDN72SE, It looks like the darker (Detail Gray?) is a better match. Did you end up using this on both your bezels?
Thanks! I have some Eastwood dark argent wheel paint on order to see how close it matches.
I found a good photo from a feeBay auction for what was described as an NOS bezel -
It doesn't appear there was much 'texture' in either the light or dark argent.
Re: Paint for 71 Charger louvered tri-color tail light bezels [Re: charger440sixpak] #2223553
12/30/16 07:16 PM
12/30/16 07:16 PM
WV
Little Detroit Offline
WV
help looking for info on T/A's Built march -april of 1970? does anybody know if there was a strike or work stoppage during that time period or a mechanical breakdown on assembly line? what dates were blocks cast? I have found several cars built within days of each other and vin's within a 1000 or less of each other all with the same issues. any help will be appreciated. thanks mike.
