Page 3 of 3 1 2 3
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2203126
11/27/16 02:09 AM
11/27/16 02:09 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Aluminum is strong enough for most any application, hardly costs any more and is lighter...........easy choice for me
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: MR_P_BODY] #2203233
11/27/16 11:29 AM
11/27/16 11:29 AM
moparx Offline
moparx  Offline
Originally Posted By MR_P_BODY
Yes they have steep gears but also have BIG tires
for the loads... they dont turn that many rpms and
it seems that trucks shops dont care if there is a
bit of vibration since they have a lot of vibrations
wave
and this is precisely the issue i have dealt with locally. there are no truck shops HERE that can, or will, high speed balance. if a quality shaft is desired, we have no choice except to order one from a reputable outfit. others have access to truck places that are very good, so that is a plus to them. here, we don't. the truck place that has the best reputation only "high speed balances" to 1000rpm, and swears .030 runout is acceptable. ok for most i guess, but not me.
beer
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2203266
11/27/16 01:04 PM
11/27/16 01:04 PM
New York
polyspheric Offline
polyspheric  Offline
New York
.030" would make me nervous.
Boffin Emeritus
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: MR_P_BODY] #2203345
11/27/16 03:20 PM
11/27/16 03:20 PM
Utah, USA
1964superstock Offline OP
Utah, USA
Myself I would go with steel on the street.. I
called Dynotech to see what I should go with..
they said DOM so I did with good U-joints and
yokes
wave
Speaking of Dynotech, I have called them over and over this month trying to contact them about my driveshaft, and no one answers the phone, goes to voicemail every time. I have left messages and sent emails, and no reply in over a month now. Seriously wondering if they are no longer in business?
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2203351
11/27/16 03:26 PM
11/27/16 03:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
yokes
wave
Its been about 2 years since I was over there.. they
had a lot of business at that time.. cant say why they
dont answer but if they closed the phone wouldnt go
to voice mail
wave
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: Monte_Smith] #2203657
11/28/16 12:35 AM
11/28/16 12:35 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If you're limited to a 3" driveshaft, is there still a weight advantage over CM steel? I'd expect the wall thickness would need to be stepped up over a 3.5".
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2267165
03/11/17 01:22 AM
03/11/17 01:22 AM
Utah, USA
Utah, USA
Update......After a long process of considering the options of driveshafts, I ended up ordering a 3.5 inch chromoly driveshaft with slip yoke from Mark Williams enterprises. MW prices were competitive with everyone, and they seem to be tough to beat with quality and balance process. MW was not in favor of using a 3.5" aluminum driveshaft with my application, mainly due to the car weight with driver (and even more with 3-4 passengers) and horsepower level. They were super fast with delivery. Currently installed and works great. Thanks everyone for the advice.
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2267184
03/11/17 02:00 AM
03/11/17 02:00 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
up up up
Best choice you could make. Did Travis help you?
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2267375
03/11/17 01:47 PM
03/11/17 01:47 PM
New York
polyspheric Offline
polyspheric  Offline
New York
MW has great tech info on site WRT length vs. RPM etc.
Boffin Emeritus
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: A727Tflite] #2267393
03/11/17 02:02 PM
03/11/17 02:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By Transman
From the above post -
"Yep... I had a well known company make a shaft
for me and it turned out to be junk.. was .040
out of true and the balance was way off.. cost
me another $350 to get another from another
company.. now all I use is Dynotech.. they are
local so I can pick it up the next day.. you
wouldnt think .040 is much but it is"
Check a late model Dodge service manual - for a truck prop shaft - .010" is max at the weld ends and .015" in the center. That's for a truck running down the road - 2000 - 3000 rpm.
Now spin that prop shaft at engine speed down the track - 6500 and above.
Yep, just went through this and mine was .008-.010 out and at 6000 r's and above it was a rattlin scary ride and now is glass smooth past 7000 where I lifted. Balanced and straight make a HUGH difference whatever the material...........Mine is a 3 1/2" CM piece FWIW and was balanced to 3200+ rpm's......... thumbs
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: Dave Hall] #2267404
03/11/17 02:15 PM
03/11/17 02:15 PM
Utah, USA
Utah, USA
Originally Posted By Dave Hall
up up up
Jason at MW was who worked with me actually. Very nice to work with.
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2267572
03/11/17 06:57 PM
03/11/17 06:57 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
MW is pretty proud of their stuff but every time I've dealt with them the service has been excellent and the product is choice!
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2267594
03/11/17 07:30 PM
03/11/17 07:30 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Remember that driveshaft speed tracks your rear axle ratio, not high gear ratio - overdrive doesn't slow the driveshaft down.
Boffin Emeritus
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2267632
03/11/17 08:52 PM
03/11/17 08:52 PM
AndyF Offline
AndyF  Offline
It has been a few years but I think that when we updated Tim's road race Valiant he picked up an aluminum driveshaft in a wrecking yard and then we had a local shop shorten it. The OEM aluminum driveshafts are filled with a cardboard like material so you have to be careful when you weld on them.
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: AndyF] #2267903
03/12/17 10:18 AM
03/12/17 10:18 AM
moparx Offline
moparx  Offline
i've often wondered about that cardboard stuff. how far away from the weld area should it be, and how much does it affect the balance ?
beer
Page 3 of 3 1 2 3
