70-71 3spd e body wiper motor arm #2202460
11/25/16 05:32 PM
11/25/16 05:32 PM
WI
W
wannadrag Offline OP
W
WI
Are the arms reproduced for the 70-71 E body? Looking for either new or used part number 2822289
Re: 70-71 3spd e body wiper motor arm [Re: wannadrag] #2202547
11/25/16 08:11 PM
11/25/16 08:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC they are $75 for the 70-72 E body 3 spd, contact... http://www.passion4mopars.com/
Re: 70-71 3spd e body wiper motor arm [Re: wannadrag] #2202579
11/25/16 09:18 PM
11/25/16 09:18 PM
WI
W
W
WI
Says on back order and when you click on the drop down menu to click on the one you want it adds a additional $75 to the E body one to make it $150 which isn't going to happen
Re: 70-71 3spd e body wiper motor arm [Re: wannadrag] #2202608
11/25/16 09:57 PM
11/25/16 09:57 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I'm quite sure it is just $75.00 for the 289 arm and $25.00 for the 518 arm.
If you're not hung up on numbers and if you are creative you can enlarge the 518 opening to fit perfectly .
Both are same angle, same dimensions.
Re: 70-71 3spd e body wiper motor arm [Re: wannadrag] #2202706
11/26/16 12:48 AM
11/26/16 12:48 AM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
I have a few original's one , also I had some repro's ( no part number ) done, if interested.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2013296
Stephan
Re: 70-71 3spd e body wiper motor arm [Re: wannadrag] #2202732
11/26/16 02:04 AM
11/26/16 02:04 AM
WI
W
W
WI
I could care less about numbers,just need one that works.PM sent Staphan
Re: 70-71 3spd e body wiper motor arm [Re: wannadrag] #2203437
11/27/16 06:49 PM
11/27/16 06:49 PM
Sunny FL
P
p4m Offline
p4m  Offline
P
Sunny FL
I didn't have an issue adding one to my cart? I know I have 8 plated currently and available. I have more that haven't been plated, but on the website they are plated. Sorry if you had difficulty on the website, but trying it just now, I had no issue adding it to the cart :-(
