Re: 1967 Dana 60 BOM number B-body, specifically RO/WO23
[Re: sawdust]
#2201958
11/24/16 05:42 PM
11/24/16 05:42 PM
Posts: 1,978 USA
Suregrip391
USA
Anyone know what the BOM number should be for 1967 B-Body. Also for the RO/WO cars with Dana. TIA The correct BOM number for a 66/67 is 602829 I would sure like one myself if any are out there. 3.54 please 😀
[Re: Suregrip391]
#2202091
11/24/16 11:07 PM
11/24/16 11:07 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Anyone know what the BOM number should be for 1967 B-Body. Also for the RO/WO cars with Dana. TIA The correct BOM number for a 66/67 is 602829 I would sure like one myself if any are out there. 3.54 please 😀 What would you need an old hunk of metal like that for?
[Re: sawdust]
#2206812
12/03/16 02:50 AM
12/03/16 02:50 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I do have one '67 Dana 60 that i "MIGHT" part with. It is BOM 602829 2 with date stamped of 12 1 6 A1 and 12 2 6 B. It has 3.54 powerlock and the housing was stripped and painted black .
[Re: NANKET]
#2207578
12/04/16 02:56 PM
12/04/16 02:56 PM
Posts: 957 MN
Droop69
MN
Is it correct the RO/WO cars all got 4:88 gears from the factory? This would be a different carrier than the 3:54, making it a very unique Dana? The code on the fender tag of a RO/WO calls for a special order axle. I don't think they swapped them 3.54's it would be a waste of time. I think they just built them for the car with the 4.88 truck gear set in a car housing. Just like the rest of the car, it was built to spec, not a converted production car.
A unique differential is needed. Had to have the centering buttons inside for car axles, but be able to use on 4.88 gears, a carrier for the 3.54 gears would not work. This differential needed to be assembled ahead of time. This could be done with a truck sure grip differential housing with passenger internals.
Only problem with this idea is there a 1967 4.88 B-body Dana on any BOM list?
Would be nice to check a known original 4 speed RO/WO Dane rear and get the numbers.
