Clutch fan blade question... #220078
02/10/09 12:52 PM
02/10/09 12:52 PM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
Besides application, what are the actual differences between the 2863216 and 2863215 clutch fan blades?
Any help appreciated...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: Clutch fan blade question... [Re: sycboi] #220079
02/10/09 04:39 PM
02/10/09 04:39 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
215 is smaller diameter
logan426
Re: Clutch fan blade question... [Re: MLR426] #220080
02/10/09 05:30 PM
02/10/09 05:30 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Both are the same size, same number of blades and blades rivets.
The only difference is the cut on the blade.
216 is a more pronounced cut with more cut out on the edge of the blades than the 215.
216 shown here on the left, 215 on the right
Re: Clutch fan blade question... [Re: mccannix] #220081
02/10/09 05:51 PM
02/10/09 05:51 PM
under the hood
A47 Offline
A47  Offline
under the hood
if thats the only difference..why the two ??
Re: Clutch fan blade question... [Re: sycboi] #220082
02/10/09 05:57 PM
02/10/09 05:57 PM
United States
STLDuster Offline
STLDuster  Offline
United States
Where do you guys get your fans from?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Clutch fan blade question... [Re: A47] #220083
02/10/09 05:58 PM
02/10/09 05:58 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
My book shows the 215 as an 18 inch and the 216 as 18.5 inch
1969 Hemi Roadrunner 2nd owner
Re: Clutch fan blade question... [Re: 69hemibeep] #220084
02/10/09 06:24 PM
02/10/09 06:24 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I should clarify I meant the blades are the same size. Yes the parts books indicate 18.5 for the 216 and 18" for the 215.
With the two on top of each other and center lined up it actually more like 1/4" difference.
Re: Clutch fan blade question... [Re: mccannix] #220085
02/10/09 07:18 PM
02/10/09 07:18 PM
under the hood
A47 Offline
A47  Offline
under the hood
would that extra 1/2 or 1/4 make any difference in cooling ....to justify two fans almost the same
Re: Clutch fan blade question... [Re: mccannix] #220086
02/10/09 07:28 PM
02/10/09 07:28 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
Do you think the diff is due to fan noise when the clutch kick in or for different CID's????
Re: Clutch fan blade question... [Re: sycboi] #220087
02/10/09 10:11 PM
02/10/09 10:11 PM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
Thanks alot guys!
It seems with centers lined up there is a quarter inch more on each side totaling the 216 being 18.5" compared to the 215's 18." diameter.
Other than that the slightly different shape on the end of the blades seem to be the only other difference.
-Michael
SuperBeast
Re: Clutch fan blade question... [Re: STLDuster] #220088
02/10/09 10:13 PM
02/10/09 10:13 PM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
www.71sg.com
SuperBeast
