Autometer gauges and how to hook-up the Voltmeter #219984
02/10/09 12:28 PM
02/10/09 12:28 PM
Iceland
70rtshaker Offline OP
super street
super street
Iceland
Hi guys, I was wondering since I am replacing all the gauges from my cuda 71, and installing Autometer gauges, do i hook-up the Voltmeter the same way as the original, or is there another method of doing this?
Thordur Ingvarsson, Reykjavik Iceland 1970 Dodge Challenger R/T 440 sixpack Shaker(sold) 1971 Plymouth Cuda pro-street project 2007 YAMAHA YZF R1 189 HP 2007 YAMAHA FZ1 SA 150 HP 2003 Mercedes Benz E-200 Kompressor 163 HP toti62@internet.is
Re: Autometer gauges and how to hook-up the Voltmeter [Re: 70rtshaker] #219985
02/10/09 12:55 PM
02/10/09 12:55 PM
Maine
itali83 Offline
itali83  Offline
Maine
You do not hook it up the same as the factory because the factory was actually an ammeter, measured amperage and not voltage. To hook up your volt guage, just find any wire that is powered with the switch in the ON position that doesn't have a big electrical load already on it and that'll tell you voltage. The directions should tell you how to do it also.
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: Autometer gauges and how to hook-up the Voltmeter [Re: itali83] #219986
02/10/09 01:02 PM
02/10/09 01:02 PM
Iceland
super street
super street
Iceland
And what do I do with the existing two big wires that used to run for the Amp-meter?
Re: Autometer gauges and how to hook-up the Voltmeter [Re: 70rtshaker] #219987
02/10/09 01:06 PM
02/10/09 01:06 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Those 2 wires need to be connected together
You can use a small nut and bolt and wrap it with electrical tape, or do with a proper crimp connector and shrink tubing over it.
Re: Autometer gauges and how to hook-up the Voltmeter [Re: OzHemi] #219988
02/10/09 01:18 PM
02/10/09 01:18 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
In other words the original amp meter wire is positive in and positve out (IE the same 12v wire). The volt meter is a positive wire (12 volt) on one side and neg wire (ground) on the other side.
Re: Autometer gauges and how to hook-up the Voltmeter [Re: Classof70Chally] #219989
02/10/09 01:20 PM
02/10/09 01:20 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Or in yet another way..
Ammeter = in series.
Volt meter = in parallel
Re: Autometer gauges and how to hook-up the Voltmeter [Re: 70rtshaker] #219990
02/10/09 02:49 PM
02/10/09 02:49 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
If you're eliminating the amp gauge anyway, then it might be worth doing this mod while you're at it: http://www.madelectrical.com/electricaltech/amp-gauges.shtml
Re: Autometer gauges and how to hook-up the Voltmeter [Re: 70Duster440] #219991
02/10/09 03:02 PM
02/10/09 03:02 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
one of the best cheap, simple, SAFE upgrades you can do, especially if you already have the voltmeter.
Re: Autometer gauges and how to hook-up the Voltmeter [Re: dirtybee] #219992
02/10/09 06:05 PM
02/10/09 06:05 PM
Iceland
super street
super street
Iceland
Thanks great info.
