Wood 440 transport stand #2199531
11/20/16 07:33 PM
11/20/16 07:33 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
I'm building a wood stand to transport my 440 home from the shop. The oil pan rails sit on the wood. My questions is how far apart are the oil pan rails on a 440. Mine is in the shop so I cant measure. It will have the oil pan on it. A complete engine.
Sanman68
Re: Wood 440 transport stand [Re: sanman68] #2199562
11/20/16 08:37 PM
11/20/16 08:37 PM
I just went & checked & if you make the wood sides 8&1/2" across on the inside it will clear the pan and give you enough room to add some cardboard or rags to protect the sides of the pan. C to C across on the bolt holes is 9&1/16".
Re: Wood 440 transport stand [Re: RapidRobert] #2199573
11/20/16 09:02 PM
11/20/16 09:02 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I picked up a couple of road race tires from a shop that used to prep Porsches for the local rich guys. They were worn out (tread only) but the side walls are incredibly stiff and they were free for the asking. I got one for small blocks and a bigger one for big blocks. Some years ago, I bought a complete 440 from Cab Burge in Oregon and brought it home in a little U-Haul trailer that I towed with my truck. I had to use the U-Haul because the engine would not fit in the truck bed with the canopy on when we tried to load it with his cherry picker. I brought it home in a snow storm.
BTW Cab, we are finally going to use the engine in a '72 Cuda it will probably be faster than the Ramcharger up
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Wood 440 transport stand [Re: sanman68] #2199591
11/20/16 09:51 PM
11/20/16 09:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ya can't beat an old tire but if you're going to build a wood one, put some gussets from the bases to support the sides so they don't fold over. Don't make it much higher than necessary - maybe 1/2" higher than the pan is deep. Flop those 2x4's over and it'll give you a wide base for casters in the future. Also. you want the thing to be as wide as the engine is across the heads - for stability.
Re: Wood 440 transport stand [Re: Stanton] #2199625
11/20/16 10:57 PM
11/20/16 10:57 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I built one just like that, hauled my 440 1200 miles in the back of my truck with no problem.
Re: Wood 440 transport stand [Re: sanman68] #2199642
11/20/16 11:24 PM
11/20/16 11:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I built one like that but noticed the engine weight will tend to spread the 8x2s apart unless they're tied together closer to their tops. Just leave enough room for the balancer & crank flange.
I also used Simpson Strong-Tie brackets at the 90-degree areas.
Set on a good furniture dolly, it's not hard to move around.
Re: Wood 440 transport stand [Re: sanman68] #2199650
11/20/16 11:36 PM
11/20/16 11:36 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
Thanks guys. I have a piece of plywood to screw into the front so the beams don't move apart at the top. It won't hit the balancer.
You guys are the best!
Sanman
