Re: Flywheels and big blocks, small blocks
[Re: 446acuda]
#219891
02/10/09 07:30 PM
02/10/09 07:30 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
both use 143 tooth flywheels so you are ok there. If the 400 has a cast crank you will have to get the flywheel rebalance for the correct external balance. On the pilot bearing/bushing, no issue, just shorten the input shaft and use the magnum style that fits in the torque converter hub. If it is a steel crank 400 you won't have any problems at all and can use the flywheel as is.
Steel crank 400 ?
[Re: OzHemi]
#219892
02/10/09 09:22 PM
02/10/09 09:22 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
Steel crank 400 ?
Even though steel cranks weren't used in every 400 like '70-earlier 383's, they were still used in most/all 400 manual transmission applications including trucks up to the end in '78.
[Re: 446acuda]
#219894
02/11/09 12:15 AM
02/11/09 12:15 AM
Posts: 449 Friendsville, TN
Reverend_Ron
super street
super street
Friendsville, TN
I'm pretty sure it's a cast crank if I remember correctly what the harmonic balancer looks like; do I need to take the balancer to the machine shop as well or just let them know it's a cast 440 (if thats what it is)????
68 Roadrunner, 383,4-spd
71 Superbee, Citron Yella, 383,slapstick
71 Charger 500, Autumn Bronze, 383,4-spd, A/C
72 Imperial, 2-dr hdtp
74 Charger SE, 440-auto, sunroof
84 Crew Cab Dually, 440-auto
01 Quad Cab Dually, HO Cummins;6-spd
08 H-D, Softail Custom
08 Challenger, 6.1 Hemi
[Re: Reverend_Ron]
#219895
02/11/09 12:24 AM
02/11/09 12:24 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I have owned 3 forged crank big blocks built all built after 1974. 2 stick, one auto.
I have seen 2 more in a junk yard. (75 W250, 4X4 stick and a cube van with an auto)
[Re: NTOLERANCE]
#219897
02/11/09 12:29 AM
02/11/09 12:29 AM
Reverend_Ron
super street
super street
Friendsville, TN
I could have sworn that the 400, and NP435 4 speed trans combo used a bigger flywheel...Like a 12"??? Friend of mine has that flywheel and bell housing, I'll have to ask him.
I'll be anxious to hear what your friend has to say..... I'll wait to hear from you!
[Re: Reverend_Ron]
#219898
02/11/09 08:13 AM
02/11/09 08:13 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
BB trucks use the 143 tooth wheel. Heres the 400 cast crank wheel.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: NTOLERANCE]
#219900
02/11/09 07:53 PM
02/11/09 07:53 PM
Reverend_Ron
super street
super street
Friendsville, TN
He is 100% sure that its a 12" clutch, and has more than 143 teeth.
Are you using an NP435 trans or an 833 in your truck?
I'm going to "GUESS" the NP435 because I had to get the "truck" bellhousing and not the car bellhousing. Is there a way to tell by crawling under the truck and looking?
[Re: Reverend_Ron]
#219901
02/11/09 08:46 PM
02/11/09 08:46 PM
Posts: 91 Central ILL.
twister6
Central ILL.
833 has shift levers on the drivers side, NP is a top loader( shifter mounted on top)
2003 Ram3500 Quad4x4
2000 Dodge Avenger
72 Duster
68 Dart GT
[Re: Reverend_Ron]
#219902
02/11/09 09:26 PM
02/11/09 09:26 PM
moparmarks
I've never seen a 172 tooth wheel in a pickup. I've had around 10 BB 4-spd pickups and all had the 143 tooth. I do have a 172 tooth wheel from an industial 440 pump. Heres the truck bell housing #3487272 with the 143 tooth wheel.
[Re: moparmarks]
#219903
02/11/09 09:33 PM
02/11/09 09:33 PM
NTOLERANCE
Madison Wi
I will have to measure that flywheel when I see him next.
[Re: NTOLERANCE]
#219905
02/11/09 09:36 PM
02/11/09 09:36 PM
moparmarks
Also I use the Center Force 12" clutch in my trucks.
